0 Replies Latest reply on Jul 21, 2010 2:06 AM by rick_h_r
    Error executing RDS command. Status Code:404
    rick_h_r
      The following problem really made crazy. I worked it for a whole day and still didn't figure it out. could someone help me ? Thanks a million.
      I created a project using this way:
      and select a tomcat server 6.0.*
      and my RDS configuration in my web.xml is this:
      part of my web.xml
      <servlet>
              <servlet-name>RDSDispatchServlet</servlet-name>
              <display-name>RDSDispatchServlet</display-name>
              <servlet-class>flex.rds.server.servlet.FrontEndServlet</servlet-class>
              <init-param>
                  <param-name>useAppserverSecurity</param-name>
                  <param-value>false</param-value>
              </init-param>
              <load-on-startup>10</load-on-startup>
          </servlet>
          <servlet-mapping id="RDS_DISPATCH_MAPPING">
              <url-pattern>/CFIDE/main/ide.cfm</url-pattern>
          </servlet-mapping>
      when I created my flex project, and added it to the server using the way of Add web module... . After that, I started my server, and changed to this view:
      I clicked "Connect to Data/Service..." and selected the service type "BlazeDS". When the Flash  Builder popped up a Authentication window, I checked "No password required" and clicked the OK button, and then, the problem comes out.
      Any clues for this problem? Thank you.
