• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Invoking java methods
Guest
Jul 21, 2010 Jul 21, 2010
hi
i have used flash builder 4.
i can't plugin eclipse ide.
can i invoke java methods in flash builder 4 .
is it possible.
if it's possible pls give some ideas.
thanks in advance
regards
athi
Views
386
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guest
You may need to install the Java Development Tools manually.
Add this update site (if it doesn't exist already):
http://download.eclipse.org/releases/galileo
Then look for Programming Languages -> Eclipse Java Development Tools.  Check the box, click Next and follow the instructions.  Eventually you'll be asked to restart Eclipse.  Do so and then when it loads again you'll have the Java perspective, Plugin-perspective, etc.
Cheers,
Chris
Votes
Translate
Translate
Report
Report
Contributor ,
Aug 11, 2010 Aug 11, 2010
LATEST
If you want to invoke java methods that are remote though, you might want to use a Java Remoting technology like BlazeDS.
Using a <s:RemoteObject> tag, you could connect to the server and invoke java methods.
Here is a small sample app code that helps me execute a remote java method.
   xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600"
   creationComplete="ro.getProducts()">
<fx:Script>
<![CDATA[
import mx.controls.Alert;
import mx.messaging.channels.AMFChannel;
import mx.rpc.events.FaultEvent;
import mx.rpc.events.ResultEvent;
protected function ro_resultHandler(event:ResultEvent):void
Alert.show(event.result.toString())
protected function ro_faultHandler(event:FaultEvent):void
Alert.show(event.fault.faultString);
</fx:Script>
<fx:Declarations>
<!-- Place non-visual elements (e.g., services, value objects) here -->
<s:RemoteObject id="ro"
destination="productService"
endpoint="http://localhost:8400/samples"
fault="ro_faultHandler(event)"
result="ro_resultHandler(event)"/>
</fx:Declarations>
</s:Application>
Hope this helps,
Balakrishnan V
Votes
Translate
Translate
Report
Report
