3 Replies Latest reply on Dec 10, 2017 11:21 PM by michal-44680644
    Retriving different histograms from activeDocument
    yairTechn Level 1
      Hi
      In CS4 & CS5 on the histogram menu it's possible to select different  types of histograms
      from the channel drop box.
      I can select RGB, R,G,B, Colors and luminosity.
      However when I execute a DoJavaScipt on the active document I can only get
      the luminosity or specific R, G, B histograms based on the activeChannels  container.
      How can I get the RGB or Colors histogram (I know I can sum up all the  different channels (R,G,B)
      but it seems stupid since the RGB data and color is already presented.
      Do I need to write a plug-in to extract this data for me?
        • 1. Re: Retriving different histograms from activeDocument
          I do not know javascript or photoshop scripting I only hack at code i steal from script I download. In the Photoshop CS5 Java scripting there seems to be a sample script names Histogram.jsx it get all four channels I never understood what Adobe fifth Colors was about. it looks like this
          // Function to activate all the channels according to the documents mode
          // Takes a document reference for input
          function TurnOnDocumentHistogramChannels(inDocument) {
              // see how many channels we need to activate
              var visibleChannelCount = 0
              // based on the mode of the document
              switch (inDocument.mode) {
                  case DocumentMode.BITMAP:
                  case DocumentMode.GRAYSCALE:
                  case DocumentMode.INDEXEDCOLOR:
                      visibleChannelCount = 1
                      break;
                  case DocumentMode.DUOTONE:
                      visibleChannelCount = 2
                      break;
                  case DocumentMode.RGB:
                  case DocumentMode.LAB:
                      visibleChannelCount = 3
                      break;
                  case DocumentMode.CMYK:
                      visibleChannelCount = 4
                      break;
                  case DocumentMode.MULTICHANNEL:
                      default:
                      visibleChannelCount = inDocument.channels.length + 1
                      break;
              // now get the channels to activate into a local array
              var aChannelArray = new Array()
              // index for the active channels array
              var aChannelIndex = 0
              for(var channelIndex = 0; channelIndex < inDocument.channels.length;
                      channelIndex++) {
                  if (channelIndex < visibleChannelCount) {
                      aChannelArray[aChannelIndex++] = inDocument.channels[channelIndex]
              // now activate them
              inDocument.activeChannels = aChannelArray
          // Save the current preferences
          var startRulerUnits = app.preferences.rulerUnits
          var startTypeUnits = app.preferences.typeUnits
          var startDisplayDialogs = app.displayDialogs
          // Set Adobe Photoshop CS5 to use pixels and display no dialogs
          app.preferences.rulerUnits = Units.PIXELS
          app.preferences.typeUnits = TypeUnits.PIXELS
          app.displayDialogs = DialogModes.NO
          // if there are no documents open then try to open a sample file
          if (app.documents.length == 0) {
              open(File(app.path + "/Samples/Fish.psd"))
          // get a reference to the working document
          var docRef = app.activeDocument
          // create the output file
          // first figure out which kind of line feeds we need
          if ($.os.search(/windows/i) != -1) {
              fileLineFeed = "Windows"
          } else {
              fileLineFeed = "Macintosh"
          // create the output file accordingly
          fileOut = new File("~/Desktop/Histogram.log")
          fileOut.lineFeed = fileLineFeed
          fileOut.open("w", "TEXT", "????")
          // write out a header
          fileOut.write("Histogram report for " + docRef.name)
          // find out how many pixels I have
          var totalCount = docRef.width.value * docRef.height.value
          // more info to the out file
          fileOut.write(" with a total pixel count of " + totalCount + "\n")
          // channel indexer
          // remember which channels are currently active
          var myActiveChannels = app.activeDocument.activeChannels
          // document histogram only works in these modes
          if (docRef.mode == DocumentMode.RGB ||
              docRef.mode == DocumentMode.INDEXEDCOLOR ||
              docRef.mode == DocumentMode.CMYK) {
              // activate the main channels so we can get the documents histogram
              TurnOnDocumentHistogramChannels(docRef)
              // Output the documents histogram
              OutputHistogram(docRef.histogram, "Luminosity", fileOut)
          // local reference to work from
          var myChannels = docRef.channels
          // loop through each channel and output the histogram
          for (var channelIndex = 0; channelIndex < myChannels.length; channelIndex++) {
              // the channel has to be visible to get a histogram
              myChannels[channelIndex].visible= true
              // turn off all the other channels
              for (var secondaryIndex = 0; secondaryIndex < myChannels.length;
                      secondaryIndex++) {
                  if (channelIndex != secondaryIndex) {
                      myChannels[secondaryIndex].visible= false
          // Use the function to dump the histogram
          OutputHistogram(myChannels[channelIndex].histogram,
              myChannels[channelIndex].name, fileOut)
          // close down the output file
          fileOut.close()
          alert("Histogram file saved to: " + fileOut.fsName)
          // reset the active channels
          docRef.activeChannels = myActiveChannels
          // Reset the application preferences
          app.preferences.rulerUnits = startRulerUnits
          app.preferences.typeUnits = startTypeUnits
          app.displayDialogs = startDisplayDialogs
          // Utility function that takes a histogram and name
          // and dumps to the output file
          function OutputHistogram(inHistogram, inHistogramName, inOutFile) {
              // find ouch which count has the largest number
              // I scale everything to this number for the output
              var largestCount = 0
              // a simple indexer I can reuse
              var histogramIndex = 0
              // see how many samples we have total
              var histogramCount = 0
              // search through all and find the largest single item
              for (histogramIndex = 0; histogramIndex < inHistogram.length;
                      histogramIndex++) {
                  histogramCount += inHistogram[histogramIndex]
                  if (inHistogram[histogramIndex] > largestCount)
                      largestCount = inHistogram[histogramIndex]
              // These should match
              if (histogramCount != totalCount) {
                  alert("Something bad is happening!")
              // see how much each "X" is going to count as
              var pixelsPerX = largestCount / 100
              // output this data to the file
              inOutFile.write("One X = " + pixelsPerX + " pixels.\n")
              // output the name of this histogram
              inOutFile.write(inHistogramName + "\n")
              // loop through all the items and output in the following format
              // 001
              // 002
                      histogramIndex++) {
              // I need an extra "0" for this line item to keep everything in line
              if (histogramIndex < 10)
                  inOutFile.write("0")
              if (histogramIndex < 100)
              // output the index to file
              inOutFile.write(histogramIndex)
              // some spacing to make it look nice
              inOutFile.write(" ")
              // figure out how many X’s I need
              var outputX = inHistogram[histogramIndex] / largestCount * 100
              // output the X’s
              for (var a = 0; a < outputX; a++)
                  inOutFile.write("X")
              inOutFile.write("\n")
          • 2. Re: Retriving different histograms from activeDocument
            yairTechn Level 1
            Thanks but I already have the code you've posted its from the script manuals for CS4 ac CS5
            as you can see by looking the word "Luminosity" the output of the  histogram
            is that of Luminosity and not of the RGB(compound) or Color (RGB  intersections)
            The amazing thing is that all of the histogram data is already on the  Histogram
            but you can't get access to the compound RGB or Color channels.
            if there was a way to get these compound channels histogram data
            then It would do he trick.
            • 3. Re: Retriving different histograms from activeDocument
              michal-44680644 Level 1
              try:
              alert('histogram RGB:'+app.activeDocument.histogram);
