2 Replies Latest reply on Jul 21, 2010 8:57 PM by janakamaduranga
    What application should i use to create the xml data as the input data for XFA template
    janakamaduranga
      HI,
      I need to generate pdf or html document form from existing XDP with the given xml formatted data set. We usually use word to generate content for those XFA template, as the data should be in xml format content in word document should be able to convert into xml document that is compatible with XFA template. I want to know if there is any tool to conver word doument content to xml format that is compatible with XFA template or has adobe given their own tool to create content that comply with XFA template? . Also i want to know if i can do above mention functionality jaut with adobe forms if not what are the other services that i should use. Please give me the prices of adobe forms and any other tool that i should use. Thank you
