2 Replies Latest reply on Jul 22, 2010 7:50 AM by JcFx.Eu
    Why won't my unzipped and rezipped IDML file open in InDesign?
    JcFx.Eu Level 1
      I'm a developer working on an IDML based project.
      My application opens an IDML file, inflates the contents and (for the moment, without making any changes), deflates them again.
      The result is a file which:
      a) Opens fine in any zip application
      b) My code can then reopen without problems.
      InDesign, however, throws the following error:
      "Cannot open the file "filename.idml". Adobe InDesign may not support the file format, a plug-in that supports the file format may be miussing, or the file may be open in another application."
      I have verified that the file is not open in another app, and that no plug ins are involved.
      InDesign will open the original IDML file that it exported, so there's no general error.
      I assume the issue is with the zip container not being UCF compliant, and I'm trying to diagnose what the problem might be.
      My question(s):
      1. Has anyone been through this and do they have any suggestions or guidance?
      2. Is there any way I can get InDesign to tell me in more detail why it cannot open the file?
      3. What are the most likely issues with the container?
      I have inspected both the original file and the output file using Winzip, and I append the results of a detailed diagnostic on each below. The only difference I can see is that some files in the original are not compressed (they are simply stored in the zip container), but the UCF specification seems to suggest that a container can contain either compressed or normal files, so I don't see why this should be a problem. Would this cause InDesign to have a problem?
      Many thanks in advance for any assistance. Zip file diagnostics follow.
      JcFx Eu.
      DIAGNOSTICS FOR THE ORIGINAL IDML FILE:
      Testing ...
      Current Location part 1 offset 35496
      Archive: ORIGINAL.zip   35518 bytes   2010-06-29 19:16:58
      End central directory record PK0506 (4+18)
          current  location of end-of-central-dir record: 35496 (0x00008aa8) bytes
          expected location of end-of-central-dir record: 35496 (0x00008aa8) bytes
            based on the size of the central directory of
            990 and its relative offset of 34506 bytes
          part number of this part (0000):                1
          part number of start of central dir (0000):     1
          number of entries in central dir in this part:  15
          total number of entries in central dir:         15
          size of central dir:                            990 (0x000003de) bytes
          relative offset of central dir:                 34506 (0x000086ca) bytes
          zipfile comment length:                         0
      Current Location part 1 offset 34506
      Central directory entry PK0102 (4+42): #1
          part number in which file begins (0000):        1
          relative offset of local header:                0 (0x00000000) bytes
          version made by operating system (00):          MS-DOS, OS/2, NT FAT
          version made by zip software (20):              2.0
          operat. system version needed to extract (00):  MS-DOS, OS/2, NT FAT
          unzip software version needed to extract (20):  2.0
          general purpose bit flag (0x0800) (bit 15..0):  0000.1000 0000.0000
            file security status  (bit 0):                not encrypted
            extended local header (bit 3):                no
          compression method (00):                        none (stored)
          file last modified on (0x00003cdd 0x00009a1c):  2010-06-29 19:16:56
          32-bit CRC value:                               0x898f76cb
          compressed size:                                43 bytes
          uncompressed size:                              43 bytes
          length of filename:                             8 characters
          length of extra field:                          0 bytes
          length of file comment:                         0 characters
          internal file attributes:                       0x0000
            apparent file type:                           binary
          external file attributes:                       0x00000000
            non-MSDOS external file attributes:           0x000000
            MS-DOS file attributes (0x00):                none
      Current Location part 1 offset 34552
          filename:mimetype
      Current Location part 1 offset 34560
      Central directory entry PK0102 (4+42): #2
          relative offset of local header:                81 (0x00000051) bytes
          general purpose bit flag (0x0802) (bit 15..0):  0000.1000 0000.0010
          compression method (08):                        deflated
            compression sub-type (deflation):             maximum
          32-bit CRC value:                               0x48e193fb
          compressed size:                                2516 bytes
          uncompressed size:                              14146 bytes
          length of filename:                             13 characters
      Current Location part 1 offset 34606
          filename:designmap.xml
      Current Location part 1 offset 34619
      Central directory entry PK0102 (4+42): #3
          relative offset of local header:                2640 (0x00000a50) bytes
          file last modified on (0x00003cdd 0x00009a1d):  2010-06-29 19:16:58
          32-bit CRC value:                               0xbe470667
          compressed size:                                167 bytes
          uncompressed size:                              253 bytes
          length of filename:                             22 characters
      Current Location part 1 offset 34665
          filename:META-INF\container.xml
      Current Location part 1 offset 34687
      Central directory entry PK0102 (4+42): #4
          relative offset of local header:                2859 (0x00000b2b) bytes
          32-bit CRC value:                               0xa9a4d00e
          compressed size:                                6047 bytes
          uncompressed size:                              29065 bytes
          length of filename:                             21 characters
      Current Location part 1 offset 34733
          filename:META-INF\metadata.xml
      Current Location part 1 offset 34754
      Central directory entry PK0102 (4+42): #5
          relative offset of local header:                8957 (0x000022fd) bytes
          32-bit CRC value:                               0x7557d85e
          compressed size:                                1155 bytes
          uncompressed size:                              7428 bytes
      Current Location part 1 offset 34800
          filename:Resources\Graphic.xml
      Current Location part 1 offset 34821
      Central directory entry PK0102 (4+42): #6
          relative offset of local header:                10163 (0x000027b3) bytes
          32-bit CRC value:                               0xf43a42fe
          compressed size:                                3449 bytes
          uncompressed size:                              19673 bytes
          length of filename:                             19 characters
      Current Location part 1 offset 34867
          filename:Resources\Fonts.xml
      Current Location part 1 offset 34886
      Central directory entry PK0102 (4+42): #7
          relative offset of local header:                13661 (0x0000355d) bytes
          32-bit CRC value:                               0x4accb4c4
          compressed size:                                4627 bytes
          uncompressed size:                              29487 bytes
          length of filename:                             20 characters
      Current Location part 1 offset 34932
          filename:Resources\Styles.xml
      Current Location part 1 offset 34952
      Central directory entry PK0102 (4+42): #8
          relative offset of local header:                18338 (0x000047a2) bytes
          32-bit CRC value:                               0xd75ae504
          compressed size:                                10962 bytes
          uncompressed size:                              69779 bytes
          length of filename:                             25 characters
      Current Location part 1 offset 34998
          filename:Resources\Preferences.xml
      Current Location part 1 offset 35023
      Central directory entry PK0102 (4+42): #9
          relative offset of local header:                29355 (0x000072ab) bytes
          32-bit CRC value:                               0x65ae6db3
          compressed size:                                218 bytes
          uncompressed size:                              302 bytes
          length of filename:                             12 characters
      Current Location part 1 offset 35069
          filename:XML\Tags.xml
      Current Location part 1 offset 35081
      Central directory entry PK0102 (4+42): #10
          relative offset of local header:                29615 (0x000073af) bytes
          32-bit CRC value:                               0x037dee40
          compressed size:                                692 bytes
          uncompressed size:                              2328 bytes
          length of filename:                             34 characters
      Current Location part 1 offset 35127
          filename:MasterSpreads\MasterSpread_ubc.xml
      Current Location part 1 offset 35161
      Central directory entry PK0102 (4+42): #11
          relative offset of local header:                30371 (0x000076a3) bytes
          32-bit CRC value:                               0x43b1858a
          compressed size:                                1573 bytes
          uncompressed size:                              7799 bytes
      Current Location part 1 offset 35207
          filename:Spreads\Spread_ub5.xml
      Current Location part 1 offset 35229
      Central directory entry PK0102 (4+42): #12
          relative offset of local header:                31996 (0x00007cfc) bytes
          32-bit CRC value:                               0x0bc7a874
          compressed size:                                342 bytes
          uncompressed size:                              606 bytes
      Current Location part 1 offset 35275
          filename:XML\BackingStory.xml
      Current Location part 1 offset 35295
      Central directory entry PK0102 (4+42): #13
          relative offset of local header:                32388 (0x00007e84) bytes
          32-bit CRC value:                               0x0c652477
          compressed size:                                685 bytes
          uncompressed size:                              3219 bytes
      Current Location part 1 offset 35341
          filename:Stories\Story_uff.xml
      Current Location part 1 offset 35362
      Central directory entry PK0102 (4+42): #14
          relative offset of local header:                33124 (0x00008164) bytes
          32-bit CRC value:                               0x59a2cf03
          compressed size:                                646 bytes
          uncompressed size:                              3041 bytes
      Current Location part 1 offset 35408
          filename:Stories\Story_ue5.xml
      Current Location part 1 offset 35429
      Central directory entry PK0102 (4+42): #15
          relative offset of local header:                33821 (0x0000841d) bytes
          32-bit CRC value:                               0x6fc8a48f
          compressed size:                                634 bytes
          uncompressed size:                              2935 bytes
      Current Location part 1 offset 35475
          filename:Stories\Story_ucb.xml
      Current Location part 1 offset 0
      Local directory entry PK0304 (4+26): #1
      Current Location part 1 offset 30
          filename:mimetype
      Current Location part 1 offset 38
      Testing mimetype                 OK
      Current Location part 1 offset 81
      Local directory entry PK0304 (4+26): #2
      Current Location part 1 offset 111
      Current Location part 1 offset 124
      Testing designmap.xml            OK
      Current Location part 1 offset 2640
      Local directory entry PK0304 (4+26): #3
      Current Location part 1 offset 2670
      Current Location part 1 offset 2692
      Testing META-INF\container.xml   OK
      Current Location part 1 offset 2859
      Local directory entry PK0304 (4+26): #4
      Current Location part 1 offset 2889
      Current Location part 1 offset 2910
      Testing META-INF\metadata.xml    OK
      Current Location part 1 offset 8957
      Local directory entry PK0304 (4+26): #5
      Current Location part 1 offset 8987
      Current Location part 1 offset 9008
      Testing Resources\Graphic.xml    OK
      Current Location part 1 offset 10163
      Local directory entry PK0304 (4+26): #6
      Current Location part 1 offset 10193
      Current Location part 1 offset 10212
      Testing Resources\Fonts.xml      OK
      Current Location part 1 offset 13661
      Local directory entry PK0304 (4+26): #7
      Current Location part 1 offset 13691
      Current Location part 1 offset 13711
      Testing Resources\Styles.xml     OK
      Current Location part 1 offset 18338
      Local directory entry PK0304 (4+26): #8
      Current Location part 1 offset 18368
      Current Location part 1 offset 18393
      Testing Resources\Preferences.xml   OK
      Current Location part 1 offset 29355
      Local directory entry PK0304 (4+26): #9
      Current Location part 1 offset 29385
      Current Location part 1 offset 29397
      Testing XML\Tags.xml             OK
      Current Location part 1 offset 29615
      Local directory entry PK0304 (4+26): #10
      Current Location part 1 offset 29645
      Current Location part 1 offset 29679
      Testing MasterSpreads\MasterSpread_ubc.xml   OK
      Current Location part 1 offset 30371
      Local directory entry PK0304 (4+26): #11
      Current Location part 1 offset 30401
      Current Location part 1 offset 30423
      Testing Spreads\Spread_ub5.xml   OK
      Current Location part 1 offset 31996
      Local directory entry PK0304 (4+26): #12
      Current Location part 1 offset 32026
      Current Location part 1 offset 32046
      Testing XML\BackingStory.xml     OK
      Current Location part 1 offset 32388
      Local directory entry PK0304 (4+26): #13
      Current Location part 1 offset 32418
      Current Location part 1 offset 32439
      Testing Stories\Story_uff.xml    OK
      Current Location part 1 offset 33124
      Local directory entry PK0304 (4+26): #14
      Current Location part 1 offset 33154
      Current Location part 1 offset 33175
      Testing Stories\Story_ue5.xml    OK
      Current Location part 1 offset 33821
      Local directory entry PK0304 (4+26): #15
      Current Location part 1 offset 33851
      Current Location part 1 offset 33872
      Testing Stories\Story_ucb.xml    OK
      No errors detected in compressed data of ORIGINAL.zip.
      DIAGNOSTICS FOR THE REZIPPED IDML FILE:
      Testing ...
      Current Location part 1 offset 34822
      Archive: OUTPUT.zip   34844 bytes   2010-07-21 17:48:46
          current  location of end-of-central-dir record: 34822 (0x00008806) bytes
          expected location of end-of-central-dir record: 34822 (0x00008806) bytes
            990 and its relative offset of 33832 bytes
          relative offset of central dir:                 33832 (0x00008428) bytes
      Current Location part 1 offset 33832
          general purpose bit flag (0x0008) (bit 15..0):  0000.0000 0000.1000
            extended local header (bit 3):                yes
            compression sub-type (deflation):             normal
          file last modified on (0x00003ce3 0x00008e13):  2010-07-03 17:48:38
          compressed size:                                44 bytes
      Current Location part 1 offset 33878
          filename:mimetype
      Current Location part 1 offset 33886
          relative offset of local header:                98 (0x00000062) bytes
          32-bit CRC value:                               0x65263983
          compressed size:                                2412 bytes
          uncompressed size:                              13985 bytes
      Current Location part 1 offset 33932
      Current Location part 1 offset 33945
          relative offset of local header:                2569 (0x00000a09) bytes
          32-bit CRC value:                               0x817f37ea
          compressed size:                                132 bytes
          uncompressed size:                              196 bytes
      Current Location part 1 offset 33991
      Current Location part 1 offset 34013
          relative offset of local header:                2769 (0x00000ad1) bytes
          32-bit CRC value:                               0xb473efef
          compressed size:                                5820 bytes
          uncompressed size:                              28411 bytes
      Current Location part 1 offset 34059
      Current Location part 1 offset 34080
          relative offset of local header:                8656 (0x000021d0) bytes
          32-bit CRC value:                               0x4ad6eac1
          compressed size:                                1118 bytes
          uncompressed size:                              7372 bytes
      Current Location part 1 offset 34126
      Current Location part 1 offset 34147
          relative offset of local header:                9841 (0x00002671) bytes
          32-bit CRC value:                               0x0772a978
          compressed size:                                3389 bytes
          uncompressed size:                              19609 bytes
      Current Location part 1 offset 34193
      Current Location part 1 offset 34212
          relative offset of local header:                13295 (0x000033ef) bytes
          32-bit CRC value:                               0x1f2c4331
          compressed size:                                4584 bytes
          uncompressed size:                              29431 bytes
      Current Location part 1 offset 34258
      Current Location part 1 offset 34278
          relative offset of local header:                17945 (0x00004619) bytes
          32-bit CRC value:                               0x80882ae8
          compressed size:                                10815 bytes
          uncompressed size:                              69723 bytes
      Current Location part 1 offset 34324
      Current Location part 1 offset 34349
          relative offset of local header:                28831 (0x0000709f) bytes
          32-bit CRC value:                               0xfb946939
          compressed size:                                181 bytes
          uncompressed size:                              246 bytes
      Current Location part 1 offset 34395
      Current Location part 1 offset 34407
          relative offset of local header:                29070 (0x0000718e) bytes
          32-bit CRC value:                               0x093d1c80
          compressed size:                                656 bytes
          uncompressed size:                              2271 bytes
      Current Location part 1 offset 34453
      Current Location part 1 offset 34487
          relative offset of local header:                29806 (0x0000746e) bytes
          32-bit CRC value:                               0x19750527
          compressed size:                                1536 bytes
          uncompressed size:                              7722 bytes
      Current Location part 1 offset 34533
      Current Location part 1 offset 34555
          relative offset of local header:                31410 (0x00007ab2) bytes
          32-bit CRC value:                               0x97ca2b81
          compressed size:                                306 bytes
          uncompressed size:                              550 bytes
      Current Location part 1 offset 34601
      Current Location part 1 offset 34621
          relative offset of local header:                31782 (0x00007c26) bytes
          32-bit CRC value:                               0x7f9369e2
          compressed size:                                644 bytes
          uncompressed size:                              3162 bytes
      Current Location part 1 offset 34667
      Current Location part 1 offset 34688
          relative offset of local header:                32493 (0x00007eed) bytes
          32-bit CRC value:                               0xada38583
          compressed size:                                609 bytes
          uncompressed size:                              2984 bytes
      Current Location part 1 offset 34734
      Current Location part 1 offset 34755
          relative offset of local header:                33169 (0x00008191) bytes
          32-bit CRC value:                               0x10fe811c
          compressed size:                                596 bytes
          uncompressed size:                              2878 bytes
      Current Location part 1 offset 34801
          32-bit CRC value:                               0x00000000
          compressed size:                                0 bytes
          uncompressed size:                              0 bytes
        note: "real" crc and sizes are in the extended local header
        caution: value of lrec.crc32 (32-bit CRC value) changed from 0 to -1987086645
        caution: value of lrec.csize (compressed size) changed from 0 to 44
        caution: value of lrec.ucsize (uncompressed size) changed from 0 to 43
          filename:mimetype
      Testing mimetype                 OK
      Current Location part 1 offset 82
      Extended local dir entry PK0708 (4+12): #1
      Current Location part 1 offset 98
        caution: value of lrec.crc32 (32-bit CRC value) changed from 0 to 1697003907
        caution: value of lrec.csize (compressed size) changed from 0 to 2412
        caution: value of lrec.ucsize (uncompressed size) changed from 0 to 13985
      Current Location part 1 offset 128
      Current Location part 1 offset 141
      Current Location part 1 offset 2553
      Extended local dir entry PK0708 (4+12): #2
      Current Location part 1 offset 2569
        caution: value of lrec.crc32 (32-bit CRC value) changed from 0 to -2122369046
        caution: value of lrec.csize (compressed size) changed from 0 to 132
        caution: value of lrec.ucsize (uncompressed size) changed from 0 to 196
      Current Location part 1 offset 2599
      Current Location part 1 offset 2621
      Current Location part 1 offset 2753
      Extended local dir entry PK0708 (4+12): #3
      Current Location part 1 offset 2769
        caution: value of lrec.crc32 (32-bit CRC value) changed from 0 to -1267470353
        caution: value of lrec.csize (compressed size) changed from 0 to 5820
        caution: value of lrec.ucsize (uncompressed size) changed from 0 to 28411
      Current Location part 1 offset 2799
      Current Location part 1 offset 2820
      Current Location part 1 offset 8640
      Extended local dir entry PK0708 (4+12): #4
      Current Location part 1 offset 8656
        caution: value of lrec.crc32 (32-bit CRC value) changed from 0 to 1255598785
        caution: value of lrec.csize (compressed size) changed from 0 to 1118
        caution: value of lrec.ucsize (uncompressed size) changed from 0 to 7372
      Current Location part 1 offset 8686
      Current Location part 1 offset 8707
      Current Location part 1 offset 9825
      Extended local dir entry PK0708 (4+12): #5
      Current Location part 1 offset 9841
        caution: value of lrec.crc32 (32-bit CRC value) changed from 0 to 124955000
        caution: value of lrec.csize (compressed size) changed from 0 to 3389
        caution: value of lrec.ucsize (uncompressed size) changed from 0 to 19609
      Current Location part 1 offset 9871
      Current Location part 1 offset 9890
      Current Location part 1 offset 13279
      Extended local dir entry PK0708 (4+12): #6
      Current Location part 1 offset 13295
        caution: value of lrec.crc32 (32-bit CRC value) changed from 0 to 522994481
        caution: value of lrec.csize (compressed size) changed from 0 to 4584
        caution: value of lrec.ucsize (uncompressed size) changed from 0 to 29431
      Current Location part 1 offset 13325
      Current Location part 1 offset 13345
      Current Location part 1 offset 17929
      Extended local dir entry PK0708 (4+12): #7
      Current Location part 1 offset 17945
        caution: value of lrec.crc32 (32-bit CRC value) changed from 0 to -2138559768
        caution: value of lrec.csize (compressed size) changed from 0 to 10815
        caution: value of lrec.ucsize (uncompressed size) changed from 0 to 69723
      Current Location part 1 offset 17975
      Current Location part 1 offset 18000
      Current Location part 1 offset 28815
      Extended local dir entry PK0708 (4+12): #8
      Current Location part 1 offset 28831
        caution: value of lrec.crc32 (32-bit CRC value) changed from 0 to -74159815
        caution: value of lrec.csize (compressed size) changed from 0 to 181
        caution: value of lrec.ucsize (uncompressed size) changed from 0 to 246
      Current Location part 1 offset 28861
      Current Location part 1 offset 28873
      Current Location part 1 offset 29054
      Extended local dir entry PK0708 (4+12): #9
      Current Location part 1 offset 29070
        caution: value of lrec.crc32 (32-bit CRC value) changed from 0 to 154999936
        caution: value of lrec.csize (compressed size) changed from 0 to 656
        caution: value of lrec.ucsize (uncompressed size) changed from 0 to 2271
      Current Location part 1 offset 29100
      Current Location part 1 offset 29134
      Current Location part 1 offset 29790
      Extended local dir entry PK0708 (4+12): #10
      Current Location part 1 offset 29806
        caution: value of lrec.crc32 (32-bit CRC value) changed from 0 to 427099431
        caution: value of lrec.csize (compressed size) changed from 0 to 1536
        caution: value of lrec.ucsize (uncompressed size) changed from 0 to 7722
      Current Location part 1 offset 29836
      Current Location part 1 offset 29858
      Current Location part 1 offset 31394
      Extended local dir entry PK0708 (4+12): #11
      Current Location part 1 offset 31410
        caution: value of lrec.crc32 (32-bit CRC value) changed from 0 to -1748358271
        caution: value of lrec.csize (compressed size) changed from 0 to 306
        caution: value of lrec.ucsize (uncompressed size) changed from 0 to 550
      Current Location part 1 offset 31440
      Current Location part 1 offset 31460
      Current Location part 1 offset 31766
      Extended local dir entry PK0708 (4+12): #12
      Current Location part 1 offset 31782
        caution: value of lrec.crc32 (32-bit CRC value) changed from 0 to 2140367330
        caution: value of lrec.csize (compressed size) changed from 0 to 644
        caution: value of lrec.ucsize (uncompressed size) changed from 0 to 3162
      Current Location part 1 offset 31812
      Current Location part 1 offset 31833
      Current Location part 1 offset 32477
      Extended local dir entry PK0708 (4+12): #13
      Current Location part 1 offset 32493
        caution: value of lrec.crc32 (32-bit CRC value) changed from 0 to -1381792381
        caution: value of lrec.csize (compressed size) changed from 0 to 609
        caution: value of lrec.ucsize (uncompressed size) changed from 0 to 2984
      Current Location part 1 offset 32523
      Current Location part 1 offset 32544
      Current Location part 1 offset 33153
      Extended local dir entry PK0708 (4+12): #14
      Current Location part 1 offset 33169
        caution: value of lrec.crc32 (32-bit CRC value) changed from 0 to 285114652
        caution: value of lrec.csize (compressed size) changed from 0 to 596
        caution: value of lrec.ucsize (uncompressed size) changed from 0 to 2878
      Current Location part 1 offset 33199
      Current Location part 1 offset 33220
      Current Location part 1 offset 33816
      Extended local dir entry PK0708 (4+12): #15
      No errors detected in compressed data of OUTPUT.zip.
