2 Replies Latest reply on Jul 22, 2010 1:42 AM by nitin_ramachandran
    How to pass object values between classes
    nitin_ramachandran
      Stating my problem below.
      My issue is surrounded between three action script classes.  These classes are mapped to remote java clesses.
      The first one is:
      package com.script.vo
          [RemoteClass(alias="vo.RouteVO")]
          [Bindable]
          public class RouteVO
              public function RouteVO()
              public var routeId:Number;
              public var fromStation:StationVO;
              public var toStation:StationVO;
              public var firstClass:int;
      Second is :
          [RemoteClass(alias="vo.SectorVO")]
          [Bindable]
          public class SectorVO
              public function SectorVO()
              public var sectorId:Number;
      Third one is :
          [RemoteClass(alias="vo.SectorMapVO")]
          [Bindable]
          public class SectorMapVO
              public function SectorMapVO()
              public var mapId:Number;
              public var route:RouteVO;
              public var sector:SectorVO;
              public var legSeq:Number;
      private function getVal():void{
      private var sectorMap:SectorMapVO = new SectorMapVO();
      private var selectedRoute:RouteVO = new RouteVO();
      //I get error in this line
      sectorMap.route = SectorMapVO(selectedRoute.routeId);
      Isn't it possible for my 3rd class object of type RouteVO to get the value of the same type? Please help me with the right code since I am new to Flex.
      Thanks in advance.
        • 1. Re: How to pass object values between classes
          Sebastien V. Level 3
          The types you are using are not the good ones.
          selectedRoute is a RouteVO, so selectedRoute.routeId is a Number. So when calling SectorMapVO(selectedRoute.routeId), you are actually trying to convert a Number into a SectorMapVO.
          sectorMap is a SectorMapVO, so route is a RouteVO. Meaning the only type of object you can assign to it is RouteVO.
          So what your last line is doing, is trying to convert a Number into a SectorMapVO, then assigning it to a RouteVO. This is very wrong.
          I suppose what you are willing to do is to assign the selectedRoute to the sectorMap (but I might very well be wrong on that). Then you should do:
          sectorMap.route = selectedRoute;
          Then if you need to access the sector map's route id, you just access sectorMap.route.routeId (supposing it has been initialized).
          Hope this helps...
          Edit: You should also remove the "private" before the two variables declarations in the function, a variable only has a scope (private, protected, public or default) when it is an object variable, but not in a function.
          • 2. Re: How to pass object values between classes
            nitin_ramachandran Level 1
            Thank you very much. That indeed helped..! Problem is solved..!
