1 Reply Latest reply on Jul 22, 2010 11:18 AM by majester8425
    Spark Dropdownlist will not set data to selectedindex following refresh ???
    majester8425 Level 1
      I have a dropdown list item on a form which gets populated from an ArrayCollection. The value selected is set depending on the value retrieved from a database for the given data being displayed.
      This works fine using the following code. Finds a match in the ArrayCollection to the retried data and sets the selectedindex. Works 100% until I update some other bit of data and refresh the screen. The code still works and the selectedindex value is set correctly, but the dropdown is now blank. If I change it to a combobox its fine, but I don’t want to allow users to enter a value in the combobox.
      for (i = 0; i < teamAc.length; i++)
                      if (teamAc[i].team_id == event.result.item.team_id_op)
                                      teamDd.selectedIndex = i;
                                      break;
                      else
                                      teamDd.selectedIndex = -1
