1 Reply Latest reply on Jul 23, 2010 2:07 AM by BhaskerChari
    Problem while adding elements to a ArrayCollection
    kiran7881 Level 1
      Hi ,
      I am trying to insert some Strings in ArrayCollection using addItem("Test")
      but it is throwing compile error showing that "the variable Test1 is not defined"
      Problem in adding elemnets to a
      Some sample code
      <mx:Application creationComplete="callMe()">
      <mx:script>
      public function callMe():void
      var ac:ArrayCollection = new ArrayCollection();
      ac.addItem("Test1");
      ac.addItem("Test2");
      ac.addItem("Test3");
      </mx:script>
      </mx:Application>
      Please let me know how can i solve this error .
      Thanks in advnace .
      I also tried using
      var str:String ="Test1";
      ac.addItem(str);
      but the problem continous
      Please help .
        • 1. Re: Problem while adding elements to a ArrayCollection
          BhaskerChari Level 4
          Hi Kiran,
          Try the below code as it is pasted below:
          I think you have used ac.addItem(Test1);  instead of ac.addItem("Test1"); ..thats why it is throwing an error...
          <?xml version="1.0"?>
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" creationComplete="callMe()">
          <mx:Script>
            <![CDATA[
             import mx.collections.ArrayCollection;
          </mx:Script>
          </mx:Application>
          Bhasker Chari
