2 Replies Latest reply on Jul 23, 2010 11:11 PM by RidNath
    Problem: Exporting to tagged text
    RidNath
      Hi All,
      When I am try to export the indd files to tagged text format it shows following errors while using the below script.
      kindly advice me where is the problem appears.
      //ExportAllText.jsx
      //An InDesign CS3 JavaScript
      //Exports all of the text in the active document as a single
      //text file. To do this, the script will create a new document,
      //combine the stories in the new document using export/import,
      //and then export the text from the new document.
      if(app.documents.length != 0){
      if(app.documents.item(0).stories.length != 0){
      myGetFileName(app.documents.item(0).name);
      function myGetFileName(myDocumentName){
      var myFilePath = File.saveDialog("Save Exported File As:");
      if(myFilePath != null){
      myDisplayDialog(myDocumentName, myFilePath);
      function myDisplayDialog(myDocumentName, myFilePath){
      //Need to get export format, story separator.
      var myExportFormats = ["Text Only", "Tagged Text", "RTF"];
      var myDialog = app.dialogs.add({name:"ExportAllStories"});
      with(myDialog.dialogColumns.add()){a
      with(dialogRows.add()){
      with(dialogColumns.add()){
      var myExportFormatDropdown = dropdowns.add({stringList:myExportFormats, selectedIndex:0});
      var myAddSeparatorCheckbox = checkboxControls.add({staticLabel:"Add separator line", checkedState:true});
      var myResult = myDialog.show();
      if(myResult == true){
      var myExportFormat = myExportFormats[myExportFormatDropdown.selectedIndex];
      var myAddSeparator = myAddSeparatorCheckbox.checkedState;
      myDialog.destroy();
      myExportAllText(myDocumentName, myFilePath, myExportFormat, myAddSeparator);
      else{
      myDialog.destroy();
      function myExportAllText(myDocumentName, myFilePath, myExportFormat, myAddSeparator){
      var myStory;
      var myTempFolder = Folder.temp;
      var myTempFile = File(myTempFolder + "/tempTextFile.txt");
      var myNewDocument = app.documents.add();
      var myDocument = app.documents.item(myDocumentName);
      var myTextFrame = myNewDocument.pages.item(0).textFrames.add({geometricBounds:myGetBounds(myNewDocument, myNewDocument.pages.item(0))});
      var myNewStory = myTextFrame.parentStory;
      for(myCounter = 0; myCounter < myDocument.stories.length; myCounter++){
      myStory = myDocument.stories.item(myCounter);
      //Export the story as tagged text.
      myStory.exportFile(ExportFormat.taggedText, myTempFile);
      //Import (place) the file at the end of the temporary story.
      myNewStory.insertionPoints.item(-1).place(myTempFile);
      //If the imported text did not end with a return, enter a return
      //to keep the stories from running together.
      if(myCounter != myDocument.stories.length -1){
      if(myNewStory.characters.item(-1).contents != "\r"){
      myNewStory.insertionPoints.item(-1).contents = "\r";
      if(myAddSeparator == true){
      myNewStory.insertionPoints.item(-1).contents = "----------------------------------------\r";
      switch(myExportFormat){
      case "Text Only":
      myFormat = ExportFormat.textType;
      myExtension = ".txt"
      break;
      case "RTF":
      myFormat = ExportFormat.RTF;
      myExtension = ".rtf"
      break;
      case "Tagged Text":
      myFormat = ExportFormat.taggedText;
      break;
      myNewStory.exportFile(myFormat, File(myFilePath));
      myNewDocument.close(SaveOptions.no);
      myTempFile.remove();
      function myGetBounds(myDocument, myPage){
      var myPageWidth = myDocument.documentPreferences.pageWidth;
      var myPageHeight = myDocument.documentPreferences.pageHeight
      if(myPage.side == PageSideOptions.leftHand){
      var myX2 = myPage.marginPreferences.left;
      var myX1 = myPage.marginPreferences.right;
      else{
      var myX1 = myPage.marginPreferences.left;
      var myX2 = myPage.marginPreferences.right;
      var myY1 = myPage.marginPreferences.top;
      var myX2 = myPageWidth - myX2;
      var myY2 = myPageHeight - myPage.marginPreferences.bottom;
      return [myY1, myX1, myY2, myX2];
      thanks
