3 Replies Latest reply on Jul 29, 2010 12:57 AM by Balakrishnan V
    Data to XML
    GeorgeWS Level 1
      I have a sample I am using that uses an xml file to populate the controls. like:
      service = new PhotoService("data/galleries.xml")
      This works but I want to gather the data from a server database instead. What should I do?
      Get data with remoteobject and convert that to an xml file? Sample?
      Thanks George
        • 1. Re: Data to XML
          rtalton Level 4
          You could use a HTTPService to load the xml file.
          • 2. Re: Data to XML
            Joshfromdallas
            you can use several methods and services, Basically you just need your SQL to output a xml file. There are some great tutes at the Learn Flash in a week page:
            http://www.adobe.com/devnet/flex/videotraining/
            Enjoy!
            • 3. Re: Data to XML
              Balakrishnan V
              Importing an xml is very easy using the DCD-wizard in Flash Builder 4.
              You can alternatively have the following mxml/As code.
                 xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" creationComplete="SendHTTPService()">
              <fx:Script>
              <![CDATA[
              protected var data:Object;
              import mx.rpc.events.ResultEvent;
              protected function SendHTTPService():void
              myHttpService.send()
              protected function myHttpService_resultHandler(event:ResultEvent):void
              data=event.result
              </fx:Script>
              <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
              <s:HTTPService id="myHttpService"
                 url="myUrl"
                 result="myHttpService_resultHandler(event)"/>
              </fx:Declarations>
              </s:Application>
              You may box your data:Object into any other datatype as well as per the requirement
              Hope  this helps,
              balakrishnan v
