0 Replies Latest reply on Jul 23, 2010 12:05 PM by ilya_k
    An internal build error has occurred. Right-click for more information
    ilya_k Level 1
      Greetings!
      We are using Eclipse 3.4 or 3,5 with Flash 4 plugin and Flex SDK 3.3.0.
      Project set comprises several, more than a couple dozen, dependent  Flex and Java projects.
      Time-to-time we run across an internal build error on all Flex projects.
      The stack trace where topmost entries are:
      So far we did not find how to get around the problem except delete project set and start from
      scratch.
      Pleas help!
      !ENTRY com.adobe.flexbuilder.project 4 43 2010-07-23 14:40:38.353
      !MESSAGE Uncaught exception in compiler
      !STACK 0
      java.lang.NullPointerException
      at com.adobe.flexbuilder.multisdk.compiler.internal.ASBuilder.applySettings(ASBuilder.java:3 25)
      at com.adobe.flexbuilder.multisdk.compiler.internal.ASApplicationBuilder.setup(ASApplication Builder.java:67)
      at com.adobe.flexbuilder.multisdk.compiler.internal.ASItemBuilder.setup(ASItemBuilder.java:5 4)
      at com.adobe.flexbuilder.project.compiler.BuilderFactory.createBuilder(BuilderFactory.java:8 0)
      at com.adobe.flexbuilder.project.compiler.BuilderFactory.createBuilder(BuilderFactory.java:5 9)
      at com.adobe.flexbuilder.project.compiler.BuilderManager.getBuilder(BuilderManager.java:192)
      When it happens you can not open project "Properties | Flex Compiler"  dialog because error
      message pops up saying "The currently displayed page contains invalid values."
      I am not sure how "an internal build error..." relates to "...displayed page contains invalid values"
      but  it worth to mention anyway.
      Thanks for your help.
