2 Replies Latest reply: Jul 26, 2010 8:32 AM by ilssac RSS
    Oracle 11g Stored Proccedure won't talk to our ColdFusion code.
    ilssac Community Member
      WHY IS JIVE SAYING THIS IS A BLANK MESSAGE?????
      We are attempting to execute a stored procedure with this piece of code.
      [Macromedia][Oracle JDBC Driver]Unhandled sql type
      The error occurred in
      D:\playground\warren\PpurComponents.cfc: line 49
      Called from D:\playground\warren\ppur_file_import.cfm: line 53
      Called from D:\playground\warren\PpurComponents.cfc: line 49
      Here is what I hope is the relevant portion of a 1400 line stored procedure located in Oracle.  We don't get to refactor the stored procedure until phase two of this project.
        • 1. Re: Oracle 11g Stored Proccedure won't talk to our ColdFusion code.
          WELL THAT SURE TURNED OUT TO BE CRAP!
          ORIGINAL MESSAGE:
          <cfstoredproc returncode="yes" datasource="purload" procedure="co_error.check_records" debug="yes">
               <cfprocparam type="in" cfsqltype="cf_sql_decimal" value="2010">
          </cfstoredproc>
          As you can see, it is a pretty small <cfstoredproc...> block.  Executing it returns this error.
          The error occurred in D:\playground\warren\PpurComponents.cfc: line 49
          PROCEDURE Check_records(p_year IN NUMBER)
           AS v_use_no               NUMBER(8);
           v_error_code           BINARY_INTEGER := 0;
           v_error_type           VARCHAR2(20);
          This project is to replace a 15 year old Perl program that used to call this procedure with this code.
          open(SQL_OUTPUT, "sqlplus -S ops\$xxxxx/yyyyyy\@dev11ge \@check_errors $year |")
          That executed this SQL file.
          * Run the error checking procedures
          SET pause off
          SET verify off
          SET TERMOUT ON
          SET FEEDBACK OFF
          SET document off
          SET serveroutput ON size 1000000 format word_wrapped
          WHENEVER SQLERROR EXIT 1 ROLLBACK
          WHENEVER OSERROR EXIT 1 ROLLBACK
          EXECUTE Co_error.Check_records(&1);
          show errors
          EXIT 0
          Can anybody provide some insight on why this won't work form our CFML?
          TIA
          Ian
          Message was edited by: ilssac  MY GOOD LORD DID THAT TAKE A LOT OF EFFORT IN ORDER TO MAKE A READABLE MESSAGE!
          Message was edited by: ilssac: After fighting with Jive I forgot to add - if we take out the returncode="yes" parameter from the <cfstoredproc...> tag, CF will not throw an exception, but the stored procedure still does not execute.
          • 2. Re: Oracle 11g Stored Proccedure won't talk to our ColdFusion code.
            More Information.
            Our stored procedure is now working.    Our DBA determined that the call  was working, but the procedure was waiting, because the previous  <cfquery..> INSERT block was not committed.  But why would that  be?  I've never had to explicity commit my INSERTS using  <cfquery...> before.  Is this something common?  Is is something  in the Database or drivers or just Oracle 11g?
            Placing a commit <cftransaction...> block around they  <cfquery..> resolved the issue.  But I have never had to do that  before.
