6 Replies Latest reply on Jul 26, 2010 1:28 PM by kglad
    Get image dimensions before onLoadInit
    aditi_bk Level 1
      I need to get the width and height of the image before it finishes loading with a moviecliploader instance. This is for placement of another clip, which will always load before the image. Is there any way of doing this??? onLoadStart does not give dimensions of the image.
      Another query is, how do I access a button within the emptymcholder, and place it at a specific position?? Is this possible??
      I tried doing emptymcholder.buttonname._x, but it does not work. Any help will be appreciated.
      Regards,
        • 1. Re: Get image dimensions before onLoadInit
          no, it's not possible and not necessary.
          your next set of questions don't make sense if emptymcholder is the load-target of your loadMovie() or loadClip() method.
          • 2. Re: Get image dimensions before onLoadInit
            aditi_bk Level 1
            You are right, there was no need to confuse things so much. What I have done is convert the image and text I was initially loading separately, into one single swf, which is being loaded into the emptymcholder, by the moviecliploader instance.
            My order is
            folioholdermc ---holds--> emptymcholder --holds--> imgdesc.swf
            Within folioholdermc, I disabled buttons and lowered opacity, once imgdesc.swf was loaded, using onloadInit()
            Now in the button inside imgdesc.swf. I called, this.unloadMovie(), which successfully unloads the file, but I am still inside emptymcholder, though I actually want to go back into folioholdermc.
            I am trying out the use of Eventlistener to check for unloadMovie. But my problem is can I place this within folioholdermc, within the onloadInit() or maybe within the on(press) function which actually calls the loader in the first place?? I need to enable the buttons within folioholdermc, and increase opacity, once the imgdesc.swf is unloaded.
            Any help on how I can go about this????
            Thanks a tonne for the response..
            • 3. Re: Get image dimensions before onLoadInit
              aditi_bk Level 1
              Within the onLoadInit() in folioholdermc I added
              _mc.addEventListener("end",endClip);
                       function endClip() {
                          trace("end");
              and in the imgdesc.swf within the back button
              on(press){
                  this.dispatchEvent({target:folioholdermc, type:"end"});
                  trace("event dispatched");
                  this.unloadMovie();
              how do I connect the two?? This is not working, as the endClip function is not being called. What am I doing wrong???
              • 4. Re: Get image dimensions before onLoadInit
                ultimately, what are you trying to do?
                • 5. Re: Get image dimensions before onLoadInit
                  aditi_bk Level 1
                  Ok I figured it out. First mistake  was that the code for dispatchevent was incomplete and placed in the  wrong place, the first frame of the imgdesc.swf. The first frame of  imgdesc.swf is apparently loaded before the onloadInit(), sending out an  event which no one is listening to.
                  So this is what I did within imgdesc.swf
                  First Frame:
                  import mx.events.EventDispatcher;
                  EventDispatcher.initialize( this
                  stop();
                  Then within the on(press) of the back button I inserted a gotoAndStop(2);
                  Second Frame:
                  this.unloadMovie();
                  this.dispatchEvent({type:"end", target: this});
                  trace("Child dispatching: end");
                  Now in the onloadInit within the parent swf I wrote
                  _mc.addEventListener("end", endClip);
                              trace("end");
                              i = 1;
                              while (i<=30) {
                              _root.folioholdermc["img"+i]._alpha = 100;
                              _root.folioholdermc["img"+i].enabled = true;
                              i++;
                  Worked perfectly!! Thanks for asking Kglad
                  • 6. Re: Get image dimensions before onLoadInit
                    you're welcome.
