11 Replies Latest reply on Jul 25, 2010 11:18 AM by nextfish
    preview difficulty
      In my first CS5 session, previews were jerky -- seemed to degrade and then sharpen every 2-3 seconds, a sort of pulsing. I'm using the same files and environment as CS4, where the problem did not occur. Tried different project settings, same result. Editing and exporting went fine (the performance improvement on export was noticeable). Pre-rendering the files reduced but did not completely eliminate the problem (and CS4 previewed the same files without pre-rendering). Am I missing some simple setting? Could there be a conflict with Quadro FX 1800 in CS5 that is not in CS4? Thanks in advance!
      Files are from:
      Sanyo Xacti HD2000
      Codec avc1 H.264/MPEG-4 AVC
      Properties of sample file:
      Type: MPEG Movie
      File Size: 59.8 MB
      Image Size: 1920 x 1080
      Pixel Depth: 32
      Frame Rate: 29.97
      Source Audio Format: 48000 Hz - compressed - Stereo
      Project Audio Format: 48000 Hz - 32 bit floating point - Stereo
      Total Duration: 00;00;35;26
      Average Data Rate: 1.7 MB / second
      Pixel Aspect Ratio: 1.0
      OS: Win7-64
      System: i7 920 12GB Corsair DDR3 1600
      Boot disk: WD1001 FALS Caviar Black 1TB 1200 rpm
      Storage: 2x WD1001 FALS Caviar Black 1TB 1200 rpm / raid 0
      Graphics: Quadro FX 1800
