6 Replies Latest reply on Aug 2, 2007 6:11 AM by bennettian
    Mozilla problem
      A website that works perfectly in IE appears briefly when using Mozilla but then disappears after about 2 secs and then shows error 404 message.
      Any suggestions please.
      Website address is www.andrewaarons.com
      Ta
        • 1. Re: Mozilla problem
          Level 7
          On Thu, 2 Aug 2007 10:25:45 +0000 (UTC), "bennettian"
          > Ta
          There is a refresh - and the page it links to is not there ?
          There is a missing > on the line above. Maybe that is the causing the
          difference between IE and Mozilla.
          The same affect appears with Safari
          <meta name="description" content="The official website of english
          artist, painter and printmaker andrew aarons"
          <meta http-equiv="refresh"
          content="1;URL=http://www.andrewaaronsart.com/index.html">
          ~Malcolm N....
          • 2. Re: Mozilla problem
            Level 7
            > Ta
            Also note you refresh was linking to index.html not index.hml
            ~Malcolm N....
            • 3. Re: Mozilla problem
              Level 7
              On Thu, 02 Aug 2007 11:45:12 +0100, Malcolm N_ <malcom@mgnixon.org.uk>
              >> Ta
              or even index.htm :-)
              ~Malcolm N....
              • 4. Re: Mozilla problem
                Level 1
                Thanks Malcolm. I tidied the code up but problem remains. Just wondering - the page contains the ieupdate.js code on it so as Flash elements work straight away (without having to activate them first) and there is one page on the site that is .asp. Could they be the problem?
                • 5. Re: Mozilla problem
                  Level 7
                  On Thu, 2 Aug 2007 11:31:53 +0000 (UTC), "bennettian"
                  I'm not a great fan of Flash - so don't use it - so someone else will
                  need to advise on that one.
                  One small point
                  <link href="css%20styles/body%20text.css" rel="stylesheet"
                  type="text/css">
                  It is advised that you do not have spaces in file names ( indicated
                  here by the %20. I'm fairly sure that this would not cause the problem
                  - but it doesn't help. I suggest you change the filename to
                  /css/bodyText.css
                  Interesting site - let us know when you have it fixed
                  Malcolm
                  Scotland
                  ~Malcolm N....
                  • 6. Re: Mozilla problem
                    Level 1
                    Thanks for your help
