12 Replies Latest reply on Jul 26, 2010 7:54 AM by efeelo
    Counting letters in a word
    efeelo Level 1
      I am using lingo to count and display letters in a word but my script is stuck on a point. Can any help to solve this?
      property
      SpriteNum
      global
      gCurrentCounter, CurrentWord, lettersofCurrentWord, sSoundName
      On
      MouseDown me
      if
      gCurrentCounter < 10 then
      p =
      "00" & gCurrentCounter
      else if
      gCurrentCounter < 100 then
      p =
      "0" & gCurrentCounter
      else
      p = gCurrentCounter
      end if
      j =
      1
      letter_no =
      spritenum
      letter_name =
      member("PE_" & string(j)).text
      letter_uppercase =
      "A"
      -- puppetSound 1, "A sound"
      CurrentWord =
      member("word - " & p)
      i =
      1
      If
      sprite (letter_no).within(sprite(spritenum)) Then
      if
      charToNum(member(CurrentWord).paragraph[1].char[1]) <= 90 then
      member
      ("pe_space_" & string(i)).text = letter_uppercase
      else
      member
      ("pe_space_" & string(i)).text = letter_name
      end if
      end if
      set the
      loc of sprite letter_no to point(300,330)
      -- i = 2
      put
      i
      -- repeat while i <= CurrentWord.char.count
      if
      charToNum(member(CurrentWord).paragraph[1].char[i]) >= 200 then
      member
      ("pe_space_" & string(i)).text = member(CurrentWord).paragraph[1].char[i]
      sprite
      (letter_no).within(sprite (10 + i))
      else
      member
      end if
      i = i +
      1
      -- end repeat
      end
      mousedown me
      end
        • 1. Re: Counting letters in a word
          Sean_Wilson Adobe Community Professional
          The code you posted is illegible. Please format it and indicate where your problem is.
          • 3. Re: Counting letters in a word
            efeelo Level 1
            I can use grab and move the letter one by one to the respective positions of
            a letter within the word to make my word, but by using on mousedown with a
            click on the letter or onkeydown is my issue here. I need to make this work
            that each letter in a word will go to its position one by one on a click or
            on pushing on the key on my keyboard to move to its position in the word
            within the space provided for it. Just as if you are spelling a word.
            • 5. Re: Counting letters in a word
              efeelo Level 1
              Hello Sean_Wilson
              I have tried twice to upload the whole code to you but it kept been
              truncated at that same point, I hope my explanation of what I am trying to
              do here is clear to you. Any suggestions will be helpful. Thanks.
              • 6. Re: Counting letters in a word
                I don't know why your code posting keeps getting truncated. Try copying it from the script editor and pasting it into the top pane of your Message Window, then copy and paste from there into the forum. Then select it all and place it in a code box, so that formatting is retained - use the >> symbol above and choose Syntax Highlighting -> Plain
                Sorry, I still don't understand what your code is trying to do.
                • 7. Re: Counting letters in a word
                  efeelo Level 1
                  property SpriteNum
                  global gCurrentCounter, CurrentWord, lettersofCurrentWord, sSoundName
                  On MouseDown me
                        if gCurrentCounter < 10 then
                          p = "00" & gCurrentCounter
                          else if gCurrentCounter < 100 then
                          p = "0" & gCurrentCounter
                          else
                          p = gCurrentCounter
                        end if
                              j = 1
                              letter_no = spritenum
                              letter_name = member("PE_" & string(j)).text
                              letter_uppercase = "A"
                              CurrentWord = member("word - " & p)
                                  i = 1
                                  If sprite (letter_no).within(sprite(spritenum)) Then
                                      if charToNum(member(CurrentWord).paragraph[1].char[1]) <= 90 then
                                          member("pe_space_" & string(i)).text = letter_uppercase
                                              else
                                          member("pe_space_" & string(i)).text = letter_name
                                      end if
                                  end if
                                  set the loc of sprite letter_no to point(300,330)
                                  -- i = 2
                                  put i
                     if charToNum(member(CurrentWord).paragraph[1].char[i]) >= 200 then
                       member("pe_space_" & string(i)).text = member(CurrentWord).paragraph[1].char[i]
                                  sprite (letter_no).within(sprite (10 + i))
                              else
                      end if
                              i = i + 1
                  end repeat
                  end mousedown me
                  • 8. Re: Counting letters in a word
                    Please explain again what your code is trying to achieve.
                    • 9. Re: Counting letters in a word
                      Mike Blaustein Level 4
                      As Sean mentioned, it would be very helpful to know what you are trying to do, and what this code is doing or not doing correctly.  But based solely upon the title of the thread, I am working under the assumption that you need to know how to count letters in a word.  Nothing in that block of code appears to be doing that or attempting to do that, so it is confusing... is the problem that it doesn't count the letters?  Or is that code unrelated to letter counting, in which case, I would question why you posted it...
                      Anyway, you can get the number of characters in any given word of text like this:
                      put "Mike".char.count
                      -- 4
                      someText="my name is Mike"
                      put someText.word[1].char.count
                      -- 2
                      So, just take whatever text you are looking for as a string, and use ".char.count" on it.
                      • 10. Re: Counting letters in a word
                        efeelo Level 1
                        Hello Sean_Wilson
                        I am trying to put a "word" together by placing one letter at a time in a
                        space "sprite"  to make up this word "series of  sprites" by using mouse
                        click on each letters of the Alphabet on my stage or by using the keys on my
                        keyboard. Using grab and move works successfully but I prefer to use the on
                        MouseDown and/or on KeyDown to move the letters to their respective
                        positions to form my word on my stage.
                        Can you still help?
                        • 11. Re: Counting letters in a word
                          So what sort of sprite/member holds the completed word?
                          Presumably the code you posted is attached to individual letters of the alphabet?
                          I have re-posted your code with questions and comments interspersed - perhaps you could addess some of these:
                          property SpriteNum
                          on mouseDown me
                            else
                              p = gCurrentCounter
                            end if
                            j = 1
                            -- I don't understand: since you declared j = 1
                            -- your local var 'letter_name' will always be member("PE_1").text
                            -- again, you have hard-coded something with no apparent reason
                            i = 1
                            if sprite (letter_no).within(sprite(spritenum)) then
                              else
                              end if
                            end if
                            sprite(letter_no).loc = point(300,330)
                            -- i = 2
                            -- i will always equal 1 because that's how you declared it above, and it isn't changed
                            put i
                            -- can you explain what this block of code is doing?
                            -- I have no idea what the various members
                            -- member("pe_space_" & string(i))
                            -- are or how they're used
                                -- 'within' is an operator that returns TRUE/FALSE
                                -- so it isn't clear what you're trying to do here
                                sprite(letter_no).within(sprite (10 + i))
                              else
                              end if
                              i = i + 1
                            end repeat
                          end mouseDown
                          • 12. Re: Counting letters in a word
                            efeelo Level 1
                            **** Hello Sean see responses to questions in RED
                                • Sean -  A complete set of sprite equal the number of letters in
                                • the word named pe_space_
                            alphabet?
                                • Sean - You assumed right
                            property SpriteNum
                            on mouseDown me
                            else
                            p = gCurrentCounter
                            end if
                            j = 1
                            letter_uppercase = "A" ***  Sean - In case the first letter is uppercase
                            i = 1
                            else
                            end if
                            end if
                            -- i = 2
                            isn't changed
                                • Yes Sean, this is the reason for my been stuck on the first sprite
                            or letter of my word. I was hoping to achive repeat effect by clicking on the mouse
                            or keydown to get word spelt.
                            But on mouseDown me or keyDown does not work with my code
                            put i - This tell me that I am stuck on i = 1
                                • Sean the pe_space_  are the fields where my letter PE_ get attached to,
                            so when I release my letters on grab and move they are within these
                            sprites/fields
                            So, Sean can still help?
                            else
                            end if
                            i = i + 1
                            end repeat
                            end mouseDown
                            Message was edited by: efeelo
