1. Re: Extract background missingin new PS CS5
Talon3x8 Jul 25, 2010 5:59 AM (in response to baobabinc)http://layersmagazine.com/photoshop-cs5-review.html Hey mate, here's an extract from the above link. It should help you out. Edge Detection: The Extract filter was left out of CS4, although it was available as a separate install. (Rumor has it that the new Edge Detection feature wasn’t ready for CS4 and was pushed back to CS5.) While the Extract filter got a lot of bad press, it was really due to misuse. Luckily, Photoshop CS5 does a better job than the filter. Selection of complex edges, such as curly hair, has always been a problem. The Edge Detection setting is now part of the Refine Edge and Refine Mask dialogs. The feature is fairly easy to use: make a selection or a layer mask, open the Refine Edge dialog (Select>Refine Edge), and use the Refine Radius tool (E) to brush over the desired area. (There’s an Erase Refinements tool [just press Shift-E] in case you don’t like the results and want to try again.) In addition, there’s a Smart Radius checkbox with a Radius adjustment slider to make selections even easier. This tool makes short work of some tough selections, but it’s not for every image. I found it worked great on some images, but not others. You still might want to bone up on using the image calculations for advanced selections.
2. Re: Extract background missingin new PS CS5
baobabinc Jul 25, 2010 6:36 AM (in response to Talon3x8)Thanks for the speedy reply.
However, I am now looking extremely blond and feeling really stupid.
Let's backtrack. In old PS you clicked on extract, it brought up the screen where you chose the brush, outlined, highlighted what you wanted to keep, hit ok and you had your extracted image on a transparent background. Cool. Worked well enough at the time.
I outlined the image now in PS CS5, clicked on the refine edge, it brought up a dialog box which gave you the option to increase the brush size, etc. However, when you then go to brush over the image, there is no color showing you what you have done, no screen shows, and nowhere to finish the job.
What am I missing here?
3. Re: Extract background missingin new PS CS5
Talon3x8 Jul 25, 2010 6:11 PM (in response to baobabinc)Thats alright!
I always find when I am learning something new that I sometimes need to see it in action. I went through and watched a whole lot of videos on the new CS5 when I first got it. Check out the video below by Adobe Evangelist Terry White, it's going to rock your world!
4. Re: Extract background missingin new PS CS5
baobabinc Jul 25, 2010 7:21 PM (in response to baobabinc)Thanks very much. You are absolutely right. It totally jogged my memory that I had seen this video in Adobe itself and should have gone there myself.
Hope this helps someone else.
5. Re: Extract background missingin new PS CS5
Talon3x8 Jul 26, 2010 4:51 PM (in response to baobabinc)No worries at all. PS. Can you mark my reply's as either The Answer or as Helpful if you found them so?
