Would it be possible in a CP5 project to have a first welcome slide that shows an animated text like "Welcome to ..." for about 40 secondes with effect "Typing Text". The animation should restart every minute until a button is clicked? I tried several settings but until now I could not get a working solution.
Hello,
Is it really important that the Text Animation starts every minute (which would mean for 40sec that it only plays once), or could you just activate 'loop' in the dialog box for the Text animation? I tried this out:
Lilybiri
"just activate 'loop' in the dialog box for the Text animation" is what I tried first, but with this and the click box I found 3 problems:
1) When the text animation (typind) is completed it immediately restarts from scratch; the complete text does not stay for a while.
2) I intend to have only presented the slide heading and footing from the master slide continousely, but the text animation being repeated once a minute with a pause of about 20 seconds before starting again.
3) When the click box comes up, the repetition of the text animation stops as well.
Just to clarify my situation and intention: I enter the classroom and set up the technical environment for the presentation; while the students are entering the classroom (may be this lasts for about 15 minutes) I want to show the welcome slide with the text animation;
a) typing effect (about 20 secondes),
b) have the text shown stable (about 20 seconds),
c) clear the text and have only heading and footing (about 20 seconds),
and these 3 steps repeated until I click to whatever in order to start over to the next slide.
Hello again,
Hope I did understand your question this time. You cannot change the duration of the animation itself, if you do not loop the animation will play once and the text will then remain fixed, as you already know without a doubt. What do you mean by 'animation for 20 sec'? You could time an effect, but not a Text animation, and I understood you inserted this with Typing text as animation.
The rest I did work out this way:
Thank You for the help. With Your information I could find out, what I was looking for. As beginner (Getting started) I had some additional work to find out the required settings for the push button, and in the end I set success action to "go to next slide" (or similar, in my version it is "zur nächsten Folie").
Fine that it seems to work now and Entschuldigung, that you had to search. Could have posted more screenshots if I had known.
Lilybiri
