2 Replies Latest reply on Jul 26, 2010 10:51 PM by kiran7881
    Getting  ArrayCollection as null when getting data from the Remote Object using  Java .
    kiran7881 Level 1
      Hi ,
      I am using FLEX and Java Combination for a Search operation .
      I am able to get data into my Java DAO class which i am testing it by using System.out.println statements .
      I am trying to use this ArrayCollection as a DataProvider for a Datgrid , but unfortunately i am getting null
      Java Code :
      From the DAO class in java , i am storing some data in ArrayList  as shown :
      String sql = "Select Name , Password from Users"
      ArrayList list = new ArrayList();
      while(rs.next())
      User user = new User();
      user.setName(rs.getString(1));
      user.setPassword(rs.getString(2));
      list.add(user);
      return list ;
      Inside FLEX :
      public var userList:ArrayCollection;
      public function ResultHandler(event:ResultEvent):void
      userList = (event.result as ArrayCollection);
      Please help how to resolve this . I am confused as this is not going into the FaultEvent so i guess there is no Exception with this .
      Need your suggestions to resolve this .
      Thanks in advance .
        • 1. Re: Getting  ArrayCollection as null when getting data from the Remote Object using  Java .
          JohanVelthuis
          I'm not familiar with the java part, but I use a similar situation with xml files webservice.
          usually you have to do something like this:
          var ac:ArrayCollection = event.result.list.user as ArrayCollection
          then there is another issue if there is no result or only one result.
          I usually do something like this:
          var ac:ArrayCollection = new ArrayCollection();
          if(event.result && event.result.list && event.result.list.user && event.result.list.user is ArrayCollection){
               ac = event.result.list.user as ArrayCollection
          }else if (event.result && event.result.list && event.result.list.user && event.result.list.user is ObjectProxy){
               //this happens if there's only one result
               ac.addItem(event.result.list.user);
          }else{
               trace("no results");
          I hope this helps. For troubleshooting you can put a trace line at the top of your resulthandler function and set a breakpoint to it. Then check your Variables window for event.result and look inside  for it's children and see what type of data that is.
          • 2. Re: Getting  ArrayCollection as null when getting data from the Remote Object using  Java .
            kiran7881 Level 1
            Thank you very much for your time . I will try this .
