5 Replies Latest reply on Jul 27, 2010 5:12 PM by gmitchel
    Photoshop CS5 Action Manager Not Responding
    gmitchel
      I've been trying to port CS4 panels to CS5. The code below compiles without an error. It runs without throwing a runtime error. However, every call to the action manager causes the code to stop. Comment out the action manager code and everything runs.
      I also notice that the mx.Alert does not open an alert dialog. It causes the same issue. The code stops.
      This code works flawlessly with CS4.
      Any suggestions would be very welcome!
      Mitch
      private function makeLuminosityEdgeMask(maskWidth:int):void {
      try {
      var docRef : Document = Photoshop.app.activeDocument;
      var docRef2 : Document = docRef.duplicate( "Duplicate" );
      var docName : String = docRef.name;
      docRef2.bitsPerChannel = BitsPerChannelType.EIGHT;
      docRef2.flatten();
      docRef2.changeMode(ChangeMode.GRAYSCALE);
      var myArtLayer: ArtLayer = ArtLayer(docRef2.activeLayer);
      // Blur photo prior to mask generation for wide and medium width masks
      switch (maskWidth) {
      case maskWidthMediumEdges: myArtLayer.applyGaussianBlur(1.0); break;
      case maskWidthWideEdges: myArtLayer.applyGaussianBlur(3.0); break;
      default: break;
      // Run the Find Edges filter
      var idFndE:Number = Photoshop.app.charIDToTypeID( "FndE" );
      Photoshop.app.executeAction( idFndE,
      null, DialogModes.NO );
      // Invert result of Find Edges filter
      myArtLayer.invert();
      // Apply curves adjustment
      var curvesShape:Array = new Array(new Array(20,0),
      new Array(60,120),
      new Array(90,180),
      new Array(145,225),
      new Array(255,255));
      myArtLayer.adjustCurves(curvesShape);
      // Apply maximum filter
      case maskWidthMediumEdges: myArtLayer.applyMaximum(1.0); break;
      case maskWidthWideEdges: myArtLayer.applyMaximum(2.0); break;
      default: break;
      // Apply median filter
      case maskWidthMediumEdges: myArtLayer.applyMedianNoise(1.0); break;
      case maskWidthWideEdges: myArtLayer.applyMedianNoise(2.0); break;
      default: break;
      // Apply Gaussian Blur
      case maskWidthExtraNarrowEdges: myArtLayer.applyGaussianBlur(0.1); break;
      case maskWidthNarrowEdges: myArtLayer.applyGaussianBlur(0.5); break;
      case maskWidthWideEdges: myArtLayer.applyGaussianBlur(2.0); break;
      default: break;
      // Apply AutoLevels to Mask
      myArtLayer.autoLevels();
      // Duplicate channel and rename
      var channelName:String;
      case maskWidthExtraNarrowEdges: channelName = maskLuminosityEdgesExtraNarrow; break;
      case maskWidthNarrowEdges: channelName = maskLuminosityEdgesNarrow; break;
      case maskWidthMediumEdges: channelName = maskLuminosityEdgesMedium; break;
      case maskWidthWideEdges: channelName = maskLuminosityEdgesWide; break;
      // Duplicate channel to original document
      var idDplc:int = Photoshop.app.charIDToTypeID( "Dplc" );
      var desc2:ActionDescriptor = new ActionDescriptor();
      var idnull:int = Photoshop.app.charIDToTypeID( "null" );
      var ref1:ActionReference = new ActionReference();
      var idChnl:int = Photoshop.app.charIDToTypeID( "Chnl" );
      var idOrdn:int = Photoshop.app.charIDToTypeID( "Ordn" );
      var idTrgt:int = Photoshop.app.charIDToTypeID( "Trgt" );
      ref1.putEnumerated( idChnl, idOrdn, idTrgt );
      desc2.putReference( idnull, ref1 );
      var idT:int = Photoshop.app.charIDToTypeID( "T " );
      var ref2:ActionReference = new ActionReference();
      var idDcmn:int = Photoshop.app.charIDToTypeID( "Dcmn" );
      ref2.putName( idDcmn, docName );
      desc2.putReference( idT, ref2 );
      var idNm:int = Photoshop.app.charIDToTypeID( "Nm " );
      desc2.putString( idNm, channelName );
      Photoshop.app.executeAction( idDplc, desc2, DialogModes.NO );
      // Close duplicate
      docRef2.close(SaveOptions.DONOTSAVECHANGES);
      // Release RAM;
      Photoshop.app.purge(PurgeTarget.ALLCACHES);
      // Refresh app
      Photoshop.app.refresh();
      // Restore Channels palette
      docRef.activeChannels = docRef.componentChannels;
      catch(error:Error) {
      Alert.show(
      "Error in makeLuminosityEdgeMask(): " + error.message);
