7 Replies Latest reply on Jul 26, 2010 11:52 PM by kiran7881
    How to Capture the Checked Row Data of a DataGrid
    kiran7881 Level 1
      I am having data inside a DataGrid as shown  .
      <mx:DataGrid id="dataGrid"dataProvider="{myAC}" x="10" y="177" visible="true">
      <mx:columns>
      <mx:DataGridColumn  headerText="SLNO" itemRenderer="mx.contrls.RadioButton"/>
      <mx:DataGridColumn dataField="EmpId" headerText="Names" />
      <mx:DataGridColumn dataField="Ename" headerText="Passwords"/>
      <mx:DataGridColumn dataField="EmpDepartment" headerText="CPasswords"/>
      </mx:DataGridColumn>
      <mx:Button x="149" y="327" label="Button" click="deleteRow()"/>
      <mx:script>
      public function deleteRow():void
      // Need logic here
      </mx:script>
      Now my requirement is that when the user checks a row inside a DataGrid and presses a Delete Button , i need to capture that EMPID .
      I am providing a Delete Button for this DataGrid as shown above .
      Please tell me how to capture that checked EMPID inside the deleteRow() function
      Thanks in advance .
        • 1. Re: How to Capture the Checked Row Data of a DataGrid
          rtalton Level 4
          In this case, you could use a foreach loop, deleting all data with a checked box. This assumes you have a field in myAC to store the value of the radioButton (selected property).
          • 2. Re: How to Capture the Checked Row Data of a DataGrid
            Flex harUI Adobe Employee
            In the example on my blog, the selectedItems contains the set of data that
            is checked
            Alex Harui
            Flex SDK Team
            Adobe System, Inc.
            http://blogs.adobe.com/aharui
            • 3. Re: How to Capture the Checked Row Data of a DataGrid
              kiran7881 Level 1
              Hi Flex harUI  ,
              Thanks for the the link you sent .
              My question is that how can i get the value of the clicked Row of a DataGrid ??
              Please help as  in my work place as we dont have access to download source of other domains .
              I need a sample code of this .
              Thanks in advance .
              • 4. Re: How to Capture the Checked Row Data of a DataGrid
                CheckBoxRenderer.as
                package
                import flash.display.DisplayObject;
                import flash.events.KeyboardEvent;
                import flash.events.MouseEvent;
                import flash.text.TextField;
                import mx.controls.CheckBox;
                import mx.controls.dataGridClasses.DataGridListData;
                import mx.controls.listClasses.ListBase;
                • The Renderer.
                public class CheckBoxRenderer extends CheckBox
                    public function CheckBoxRenderer()
                        focusEnabled = false;
                    override public function set data(value:Object):void
                        super.data = value;
                        invalidateProperties();
                    override protected function commitProperties():void
                        super.commitProperties();
                        if (owner is ListBase)
                            selected = ListBase(owner).isItemSelected(data);
                    /* eat keyboard events, the underlying list will handle them */
                    override protected function keyDownHandler(event:KeyboardEvent):void
                    override protected function keyUpHandler(event:KeyboardEvent):void
                    /* eat mouse events, the underlying list will handle them */
                    override protected function clickHandler(event:MouseEvent):void
                    /* center the checkbox if we're in a datagrid */
                    override protected function updateDisplayList(w:Number, h:Number):void
                        super.updateDisplayList(w, h);
                        if (listData is DataGridListData)
                            var n:int = numChildren;
                            for (var i:int = 0; i < n; i++)
                                var c:DisplayObject = getChildAt(i);
                                if (!(c is TextField))
                                    c.x = (w - c.width) / 2;
                                    c.y = 0;
                CheckBoxList.as
                package
                import flash.display.Sprite;
                import mx.controls.List;
                import mx.controls.listClasses.IListItemRenderer;
                • List that uses checkboxes for multiple selection
                public class CheckBoxList extends List
                    // fake all mouse interaction as if it had the ctrl key down
                    override protected function selectItem(item:IListItemRenderer,
                                                  shiftKey:Boolean, ctrlKey:Boolean,
                                                  transition:Boolean = true):Boolean
                        return super.selectItem(item, false, true, transition);
                    // turn off selection indicator
                    override protected function drawSelectionIndicator(
                                                indicator:Sprite, x:Number, y:Number,
                                                width:Number, height:Number, color:uint,
                                                itemRenderer:IListItemRenderer):void
                    // whenever we draw the renderer, make sure we re-eval the checked state
                    override protected function drawItem(item:IListItemRenderer,
                                                selected:Boolean = false,
                                                highlighted:Boolean = false,
                                                caret:Boolean = false,
                                                transition:Boolean = false):void
                        CheckBox(item).invalidateProperties();
                        super.drawItem(item, selected, highlighted, caret, transition);
                    // fake all keyboard interaction as if it had the ctrl key down
                        // this is technically illegal, but works
                        event.ctrlKey = true;
                        event.shiftKey = false;
                        super.keyDownHandler(event);
                CheckBoxHeaderRenderer.as
                package
                import flash.events.Event;
                • The Renderer.
                public class CheckBoxHeaderRenderer extends CheckBox
                    public function CheckBoxHeaderRenderer()
                    private var addedListener:Boolean = false;
                    private var partiallySelected:Boolean = false;
                            if (!addedListener)
                                addedListener = true;
                                owner.addEventListener("valueCommit", owner_changeHandler,
                false, 0, true);
                                owner.addEventListener("change", owner_changeHandler, false,
                0, true);
                            if (ListBase(owner).dataProvider.length ==
                                ListBase(owner).selectedItems.length)
                                selected = true;
                                partiallySelected = false;
                            else if (ListBase(owner).selectedItems.length == 0)
                                selected = false;
                            else
                                selected = false;
                                partiallySelected = true;
                            invalidateDisplayList();
                        if (selected)
                            // uncheck everything
                            ListBase(owner).selectedIndex = -1;
                        else
                            var n:int = ListBase(owner).dataProvider.length;
                            var arr:Array = [];
                            for (var i:int = i; i < n; i++)
                                arr.push(i);
                            ListBase(owner).selectedIndices = arr;
                        graphics.clear();
                                    c.y = 0;
                                    c.alpha = 1;
                                    if (partiallySelected)
                                        graphics.beginFill(0x000000);
                                        graphics.drawRect(c.x, c.y, c.width, c.height);
                                        graphics.endFill();
                                        c.alpha = 0.7;
                    private function owner_changeHandler(event:Event):void
                CheckBoxDataGridApp.mxml
                <?xml version="1.0" encoding="UTF-8" standalone="no"?>
                <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" verticalGap="0"
                xmlns:local="*" height="500" >
                    <mx:Script>
                    <![CDATA[
                        private var arr:Array = [
                    </mx:Script>
                    <local:CheckBoxDataGrid id="dg" initialize="dg.dataProvider=arr"
                horizontalScrollPolicy="on"
                                    allowMultipleSelection="true" change="foo.text =
                dg.selectedIndices.toString()" >
                        <local:columns>
                            <mx:DataGridColumn dataField="firstName" headerText=" "
                width="20"
                                 sortable="false" itemRenderer="CheckBoxRenderer"
                headerRenderer="CheckBoxHeaderRenderer" >
                            <mx:DataGridColumn dataField="firstName" headerText="First Name"
                            <mx:DataGridColumn dataField="lastName" headerText="Last Name"
                        </local:columns>
                    </local:CheckBoxDataGrid>
                    <mx:Label id="foo" />
                    <local:CheckBoxList id="list" initialize="list.dataProvider=arr"
                labelField="lastName" itemRenderer="CheckBoxRenderer"
                                allowMultipleSelection="true" change="bar.text =
                list.selectedIndices.toString()" >
                    </local:CheckBoxList>
                    <mx:Label id="bar" />
                </mx:Application>
                CheckBoxDataGrid.as
                package
                import mx.controls.DataGrid;
                • DataGrid that uses checkboxes for multiple selection
                public class CheckBoxDataGrid extends DataGrid
                        // only run selection code if a checkbox was hit and always
                        // pretend we're using ctrl selection
                        if (item is CheckBox)
                        return false;
                • 5. Re: How to Capture the Checked Row Data of a DataGrid
                  BhaskerChari Level 4
                  Hi Kiran
                  You can use the simple code below to get the EmpId of the selectedItem in DataGrid..
                  <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
                     <mx:Script>
                     <![CDATA[
                      import mx.controls.Alert;
                        [Bindable]private var myAC:Array = [
                           {EmpId:1001, Ename:'Harish', EmpDepartment:"IT"},
                           {EmpId:1002, Album:'Bhasker', EmpDepartment:"HARDWARE"},
                           {EmpId:1002, Album:'Pavan', EmpDepartment:"NETWORK"},
                        public function deleteEmployee():void {
                     if(dataGrid.selectedItem != null && dataGrid.selectedItem.hasOwnProperty("EmpId"))
                      var empId:int = dataGrid.selectedItem.EmpId;
                            Alert.show("EmpId=" + empId);
                     else
                      Alert.show("Please select a row to delete.");
                     </mx:Script>
                  <mx:DataGrid id="dataGrid" dataProvider="{myAC}" x="10" y="177" visible="true">
                    <mx:columns>
                     <mx:DataGridColumn  headerText="SLNO" itemRenderer="mx.controls.RadioButton"/>
                    </mx:columns>
                  </mx:DataGrid>
                  <mx:Button id="btnDelete" label="Delete" click="deleteEmployee();" />
                  </mx:Application>
                  Bhasker Chari
                  • 6. Re: How to Capture the Checked Row Data of a DataGrid
                    kiran7881 Level 1
                    Thank you FlexHarUi for your time .
                    • 7. Re: How to Capture the Checked Row Data of a DataGrid
                      kiran7881 Level 1
                      Thank you very much  Bhasker , this is what i was basically looking for ,
                      keep up the good work Mate until FLEX gets familiar to all .
