14 Replies Latest reply on Jul 28, 2010 7:35 AM by r_olsen
    [AS] Iterate over page names throws exception
    r_olsen Level 1
      Cheers,
      Something's wrong with my AS export script. Looping over pages and getting the name
      of current page will return "1" for page[0] but the exception for the following pages:
      Can't make name of item 2 of {«class page» id 179 [snip] of "test.indd" of application
      "Adobe InDesign CS3"} into type string
      Can you help the AS rookie?
           Export all open documents to single PDF documents.
           v1.0 07/2010
           Rasmus Olsen
      -- choose a folder and cast to string
      set myFolder to (choose folder) as string
      -- set timeout to 10 minutes
      with timeout of (10 * 60) seconds
           tell application "Adobe InDesign CS3"
                try
                     -- get PDF export presets as strings
                     set presets to name of PDF export presets
                     -- get selected list item as string
                     set selected to {choose from list presets} as string
                     -- iterate over documents
                     repeat with doc in documents
                          set docname to name of doc
                          -- remove extension via newname
                          set newname to text 1 thru -6 of docname
                          if (count of pages of doc) > 1 then
                               -- doc's got more than one page
                               set docpages to pages of doc
                               -- iterate over pages
                               repeat with aPage in docpages
                                    -- need help with this:
                                    -- get page name as string trows an exception with all pages except page 1
                                    set pagename to name of aPage as string
                                    display dialog pagename
                                    tell doc
                                         -- export page with pagename suffix
                                         export format "Adobe PDF" to (myFolder & newname & "_" & pagename & ".pdf") using selected without showing options
                                         close saving no
                                    end tell
                               end repeat
                          else
                               tell doc
                                    -- export page
                                    export format "Adobe PDF" to (myFolder & newname & ".pdf") using selected without showing options
                                    close saving no
                               end tell
                          end if
                     end repeat
                     -- catch..
                on error e
                     display dialog e
                end try
           end tell
      end timeout
        • 1. Re: [AS] Iterate over page names throws exception
          sstanleyau Level 4
          It may need some parens, as in:
                                        set pagename to (name of aPage) as string
          although the "as string" is redundant. But you can simplify your loop a bit, by using something like:
          repeat with i from 1 to count of pages
          set pagename to name of page i
          • 2. Re: [AS] Iterate over page names throws exception
            r_olsen Level 1
            Hey Stanley,
            The () did the trick - thanks!
            Rasmus
            • 3. Re: [AS] Iterate over page names throws exception
              r_olsen Level 1
              repeat with i from 1 to count (pages of doc)
              end repeat
              Adobe InDesign CS3 got an error: Can't get name of page 1.
              Like that?
              Rasmus
              • 4. Re: [AS] Iterate over page names throws exception
                sstanleyau Level 4
                More like:
                set pagename to name of page i of doc
                • 5. Re: [AS] Iterate over page names throws exception
                  r_olsen Level 1
                  Hi Stanley, something wierd happens. Using your code I can get the dialog
                  to display the different page names, but when trying to export I'm struck
                  by the error:
                  Adobe InDesign CS3 got an error: Can't get name of page 2 of item 1 of every document
                       set pagename to (name of page i of doc)
                       tell PDF export preferences
                            set page range to pagename
                            set view PDF to false
                       end tell
                       -- outcomment the following tell block to display all page names
                       tell doc
                            close saving no
                       end tell
                  end repeat
                  UPDATE:
                  Problem solved - I'm closing the document after the first export iteration. No wonder the page name is unavailable.. Stupid stupid
                  Message was edited by: r_olsen
                  • 6. Re: [AS] Iterate over page names throws exception
                    r_olsen Level 1
                    Hey Stanley, one last problem to overcome: close multiple documents
                         repeat with i from 1 to (count documents)
                              close document i saving no
                         end repeat
                    end tell
                    Running this with two open documents sparks the error:
                    Adobe InDesign CS3 got an error: Can't get document 2.
                    I've tried solving this be using a negative increment:
                         repeat with i from -1 to (count documents)
                         end repeat
                    end tell
                    this however reverses the problem:
                    Adobe InDesign CS3 got an error: Can't get document 0.
                    How would you do this?
                    Rasmus
                    • 7. Re: [AS] Iterate over page names throws exception
                      Muppet Mark-QAl63s Level 4
                      You can NOT have 'document 0' AppleScript is NOT zero based. So…
                      tell application "Adobe InDesign CS2"
                      repeat with i from (count documents) to 1
                      end repeat
                      end tell
                      or use the 'by' parameter in your loop positive or negative number. Without the 'by' a value of 1 is assumed…
                      • 8. Re: [AS] Iterate over page names throws exception
                        sstanleyau Level 4
                        You could just close document 1 every time. In fact, you can probably use:
                        close every document saving no
                        • 9. Re: [AS] Iterate over page names throws exception
                          r_olsen Level 1
                          function(){return A.apply(null,[this].concat($A(arguments)))}
                          end repeat
                          end tell
                          Mr. Muppet - nothing happens when I run your lines?
                          I use CS3 - dunno if that makes a difference.
                          Do you have an example of how by is used?
                          • 10. Re: [AS] Iterate over page names throws exception
                            r_olsen Level 1
                            Greetings,
                            Closing document 1, or active document won't work (same error about page name not available):
                            --pseudo code
                            repeat doc in documents
                                 repeat pages in doc
                                      export page
                                 end repeat
                                 close document 1/active document
                            end repeat
                            However closing every document at the end works. This isn't perfect when batch exporting many documents though.
                            • 11. Re: [AS] Iterate over page names throws exception
                              In AppleScript your objects are of range 1 thru (count or length of objects). So you can't supply 'document object' with a value of '0' as a valid target.
                              Here are some quick examples of using and not using the 'by' parameter…
                              -- From lower to higher values using by parameter (positive value)
                              repeat with i from 3 to 9 by 3
                              display dialog i giving up after 2
                              end repeat
                              -- From higher to lower values using by parameter (negative value)
                              repeat with i from 10 to 2 by -2
                              end repeat
                              -- NO by parameter so 1 is assumed (as long as we go lower to higher values)
                              repeat with i from 1 to 5
                              end repeat
                              -- NO by parameter (this will fail must use 'by' for higher to lower values)
                              repeat with i from 20 to 18
                              end repeat
                              • 12. Re: [AS] Iterate over page names throws exception
                                r_olsen Level 1
                                Problem solved with by
                                     repeat with i from (count documents) to 1 by -1
                                          tell document i to close saving no
                                     end repeat
                                end tell
                                Thanks to Mark and Stanley.
                                Rasmus
                                • 13. Re: [AS] Iterate over page names throws exception
                                  The problem is NOT one of AppleScript. When you are removing objects or closing documents the indexes all get re-shuffled… 2 becomes 1, 3 becomes 2 etc. One way in which you can loop is to start at the higher end and reverse down that way 'i' remains in range and no re-shuffle… Glad you have your solution…
                                  • 14. Re: [AS] Iterate over page names throws exception
                                    r_olsen Level 1
                                    Yes that's true. But I'm just a rookie, and apparently you can't substract 1 from i when messing with the length of an array (in a positive increment).
                                    You'll have to do a negative increment using by ;-)
