13 Replies Latest reply on Jan 24, 2008 6:13 AM by Newsgroup_User
    dw reorganizes my code
    Level 7
      hi
      dw reorganizes my code, it merges several short lines into one long.
      i'd like sometimes short lines to remain short.
      how do i ?
      thanks
      lenny
        • 1. Re: dw reorganizes my code
          Level 7
          On Sat, 4 Aug 2007 12:33:13 +0200, "lenny" <its@not-mine.com> wrote:
          >hi
          >how do i ?
          >thanks
          >lenny
          put
          code rewrite
          into the help system
          ~Malcolm N....
          • 3. Re: dw reorganizes my code
            Level 7
            but there's no help there
            there's no way to tell it not to merge lines
            • 4. Re: dw reorganizes my code
              Level 7
              Yes there is - read F1 help again for "Code rewrite"
              Never Rewrite Code: In Files With Extensions
              Edit | Preferences |
              Code rewriting
              put in .htm .html
              ~Malcolm N....
              • 5. Re: dw reorganizes my code
                Level 7
                i have it checked.
                and still it merges lines
                lenny
                "Malcolm N_" <malcom@mgnixon.org.uk> wrote in message
                news:tao9b3l5899qnej3emcs1p5khd8s27rb2t@4ax.com...
                > Code rewriting
                > put in .htm .html
                > ~Malcolm N....
                • 6. Re: dw reorganizes my code
                  Level 7
                  > i have it checked.
                  > lenny
                  what are you doing when it merges the lines?
                  Is it when you first open the file?
                  run commands->format source code?
                  Alan
                  Adobe Community Expert, dreamweaver
                  http://www.adobe.com/communities/experts/
                  • 7. Re: dw reorganizes my code
                    Level 7
                    On Sun, 5 Aug 2007 00:09:12 +0200, "lenny" <its@not-mine.com> wrote:
                    >i have it checked.
                    >lenny
                    You have what checked ?
                    did you put your file extensions such as .htm into the box alongside
                    " Never Rewrite Code: In Files With Extensions"
                    Read the help files !!!!!
                    ~Malcolm N....
                    • 8. Re: dw reorganizes my code
                      Level 7
                      yes i did.
                      i read. it didn't prevent dw from merging the lines...
                      thanks
                      lenny
                      • 9. Re: dw reorganizes my code
                        Level 7
                        > Alan
                        no, i didn't run this command
                        lenny
                        • 10. Re: dw reorganizes my code
                          Level 7
                          >> Alan
                          > lenny
                          WHEN is it that you think or know these lines of code are being merged?
                          Are these really distinct lines of code with hard line returns? and then you
                          do ~something~ or choose some menu option in dreamweaver that does
                          ~something~, and the hard line returns in the code are not there- fill in
                          the blanks for the missing steps please.
                          Please if possible, give me a short step by step by step example of what the
                          problem is.
                          Alan
                          • 11. Re: dw reorganizes my code
                            Barb
                            I'm having the same problem as Lenny (I think) where Dreamweaver is rewriting my code.
                            In my preferences, under "code rewriting", I have UNCHECKED every checkbox, so nothing should be rewritten. In the "never rewrite code" box, I have:
                            .as .asr .asc .asp .ascx .asmx .aspx .cfc .cfm .cfml .config .cs .ihtml .js .jsp .php .php3 .vb .xml .xsl .xslt .xul
                            Under URL encoding, I have "do not encode special characters selected".
                            Yet when upon opening certain files, it continues to rewrite my code! Here is an example:
                            <select name="sYearofbirth" >
                            <option value="">
                            <cfoutput>
                            <cfloop index="y" from="1989" to="1900" step="-1">
                            <option value=#y# <cfif qsurv.yearofbirth eq #y#> selected</cfif> >#y#
                            </cfloop>
                            </cfoutput>
                            </select>
                            is rewritten to:
                            <option value="">
                            <cfoutput>
                            </cfoutput>
                            </cfloop>
                            </select>
                            which leads to an invalidly nested <cfloop> error.
                            I realize there may be things that DW doesn't like (no ending </option> tags or even code above this that it doesn't like, but the point is that I turned OFF code rewriting and it still does it every time I open the file!
                            I'm not 100% sure, but I think I started having this problem sometime before 1/8/08 and I don't know if it coincided with any updates.
                            I'm using DW CS3 on a Mac and I'm going nuts . . . any help would be greatly appreciated.
                            • 12. Re: dw reorganizes my code
                              Barb Level 1
                              Oh yeah, and the file that I am referring to is a .cfm file.
                              • 13. Re: dw reorganizes my code
                                Level 7
                                The default DOCTYPE in CS3 is XHTML 1.0 Transitional, which doesn't
                                permit leaving out the ending </option> tag. If you want to use that
                                style of coding, change the DOCTYPE to HTML 4.01 Transitional. See if
                                that solves your problem.
                                David Powers, Adobe Community Expert
                                Author, "The Essential Guide to Dreamweaver CS3" (friends of ED)
                                Author, "PHP Solutions" (friends of ED)
                                http://foundationphp.com/
