1 Reply Latest reply on Jul 27, 2010 11:53 PM by Karthik R.
    what are best settings to export .mov file? my video skips
    redsox05 Level 1
      what are the best settings to export .mov file? I have 1280x720 movie and I can export it no problem but sometimes it skips or gets stuck when I play it. I'm not sure if it's my video card or the actual file. I was using the H.264 setting and compressor quality best.
      thanks.
        • 1. Re: what are best settings to export .mov file? my video skips
          Karthik R. Level 2
          Like you suggested it could be a problem with your hardware which is not able to render the video at that paticular resolution,
          I  tried the same thing and it works fine for me without any issues. You  can always export the movie to a format that you want and then use other  video converter softwares to get the desired format. If your video does  not work then too, you can for sure point out that there is a problem  with your hardware.
