0 Replies Latest reply on Jul 27, 2010 7:36 AM by dd3000
    Upgrade from LiveCycle 7.0 to ES
    dd3000
      We are attempting to upgrade an application that uses LiveCycle Forms and Reader Extensions 7.0 Server to ES. Using the turnkey installation option, I have installed the LiveCycle Forms and the Reader Extensions on a new Server running Windows 2008 and JBoss. I have also installed the 7.x compatibility layer. I migrated our application, which is contained in a .war file, to the deploy directory on the new server. I am able to render a PDF document on the new server, but each time I attempt to Reader Enable the document I receive the following error:
      2010-07-09 15:23:37,466 ERROR [org.apache.catalina.core.ContainerBase.[jboss.web].[localhost].[/mycentury].[GetForm]] Servlet.service() for servlet GetForm threw exception
      java.lang.NoClassDefFoundError: com.adobe.service.ConnectionFactory
          at com.century.forms.dao.AdobePDFManager.class$(AdobePDFManager.java:574)
          at com.century.forms.dao.AdobePDFManager.rightsEnable(AdobePDFManager.java:573)
          at com.century.forms.services.AdobeFSService.readerEnablePDF(AdobeFSService.java:355)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
          at java.lang.reflect.Method.invoke(Unknown Source)
          at electric.util.reflect.Invocation.execute(Unknown Source)
          at electric.util.reflect.Invocation.invoke(Unknown Source)
          at electric.service.object.ObjectService.invoke(Unknown Source)
          at electric.proxy.handler.Proxy.invoke(Unknown Source)
          at $Proxy536.readerEnablePDF(Unknown Source)
          at com.century.forms.services.GetForm.execReaderEnablePDF(GetForm.java:266)
          at com.century.forms.services.GetForm.doGet(GetForm.java:80)
          at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
          at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
          at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:290)
          at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
          at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
          at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:235)
          at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:230)
          at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
          at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.ja va:179)
          at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:84)
          at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
          at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:104)
          at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java: 157)
          at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
          at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:241)
          at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
          at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.ja va:580)
          at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
          at java.lang.Thread.run(Unknown Source)
      And here is the code that is causing the exception:
                  // Create  PDF manipulation object. We will use this object
                  // to enable usage rights for the PDF document.
                  Object obj = initialContext.lookup("PDFManipulation");
                  ConnectionFactory connectionFactory = (ConnectionFactory)PortableRemoteObject.narrow(obj, ConnectionFactory.class);
                  PDFFactory pdfFactory = PDFFactoryHelper.narrow((org.omg.CORBA.Object)connectionFactory.getConnection());
      Thanks for any help you can provide.
