Background Information: The form guide architecture changed between LiveCycle ES and LiveCycle ES2. Form guides in ES2 exist in separate .guide file, whereas form guides in ES are embedded inside a .xdp form. We have a process that needs to render ES2 form guides. The process needs to output the rendered form guide as .swf for loading from within a flex application.
The Problem: We need to be able to render the ES2 form guide by loading a .swf from within a flex application. The problem is that the ES2 form guide rendering service doesn't let you do this. This guide-rendering service is Guides (system)/Processes/Generate Guide. It outputs an HTML wrapper that is a webpage that loads the form guide .swf's.
Does anyone know how to render an ES2 form guide as just a .swf, without the HTML wrapper??
