4 Replies Latest reply on Aug 23, 2010 12:25 PM by chris.campbell
    Adobe AIR deployment
    bluestainedivy
      Admittedly, I'm green to software deployments in an enterprise type environment, but I'm trying to deploy various Adobe software packages to users (~500). Air is one in particular that I've been wrestling with. I get an error message every time I try to run the .msi installer saying "Could not access network location (computed)". The .msi is something I extracted from the local settings temp folder as I've done with other apps I've tried to deploy. I've searched on the error a bit, but other than some conflicts between CS3 and Office I've not seen anyone else with this problem.
      My question is: is AIR not meant to be deployed with an .msi file and if so, what are the recommended ways to deploy it?
      Thanks in advance for the help.
        • 1. Re: Adobe AIR deployment
          chris.campbell Adobe Employee
          Here's a good article describing enterprise deployment
          Distributing AIR in the enterprise
          I'd also like to recommend reviewing our Runtime Redistribution website.
          Hope this helps,
          Chris
          • 2. Re: Adobe AIR deployment
            bluestainedivy Level 1
            Hey Chris,
            Sorry for the delayed response. I'll take a look at this when I can get caught up...I've been away from the office.
            I appreciate the help.
            Daniel Roberts
            979.458.3529
            • 3. Re: Adobe AIR deployment
              Rosskoba
              I have the same issue.
              The document linked above reccomends using SMS which costs close to $1000.
              When we distribute third party software, we use GPOs to deploy software packages, which only work if you have a .msi file.
              Java and Adobe both provide .msi packages for their software, however Adobe does not provide .msi downloads for Adobe AIR, only for their Flash and Reader. I can only download .exe for AIR.
              In the past, when I need to deploy .exe packages, I use a program called 7Zip to extract the .exe, which provides me with a .msi package that I can deploy using a GPO.
              This does not work with Adobe AIR. When you try to install the .msi an error message comes up saying:
              This does not make sense since I am trying to install the program locally, it is not even looking over the network for the file.
              Has anyone run in to this before? I need to resolve this issue so AIR can be deployed to ~100 Workstations.
              • 4. Re: Adobe AIR deployment
                Moved discussion to the Desktop Development forum
