2 Replies Latest reply on Jul 28, 2010 6:26 AM by saisri2k2
    i need date format ?
    welcomecan Level 1
      hi friends,
               i get data form coldfusion.i want to change date format. and display in label
      give examples
      thaks in advance
      regards welcome
        • 1. Re: i need date format ?
          BhaskerChari Level 4
          Hi WelcomeCan,
          Make use of the DateFormatter and format your date as you wish to display using formatString property..
          Check below for Sample code..example....
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
              <mx:Script>
                  <![CDATA[
                      import mx.events.ValidationResultEvent;
                      private var vResult:ValidationResultEvent;
                      // Event handler to validate and format input.
                      private function Format():void
                          vResult = dateVal.validate();
                          if (vResult.type==ValidationResultEvent.VALID) {
                              formattedDate.text=dateFormatter.format(dob.text);
                          else {
                              formattedDate.text= "";
              </mx:Script>
              <mx:DateFormatter id="dateFormatter" formatString="month: MM, day: DD, year: YYYY"/>
              <mx:DateValidator id="dateVal" source="{dob}" property="text" inputFormat="mm/dd/yyyy"/>
              <mx:Panel title="DateFormatter Example" width="95%" height="95%"
                      paddingTop="10" paddingLeft="5" paddingRight="5" paddingBottom="10">
                  <mx:Form width="100%">
                      <mx:FormItem label="Enter date (mm/dd/yyyy):" width="100%">
                          <mx:TextInput id="dob" text=""/>
                      </mx:FormItem>
                      <mx:FormItem label="Formatted date: " width="100%">
                          <mx:TextInput id="formattedDate" text="" editable="false"/>
                      </mx:FormItem>
                      <mx:FormItem>
                          <mx:Button label="Validate and Format" click="Format();"/>
                      </mx:FormItem>
                  </mx:Form>
              </mx:Panel>
          </mx:Application>
          Bhasker Chari
          • 2. Re: i need date format ?
            saisri2k2 Level 4
            http://code.google.com/p/flexdateutils/downloads/list
            Instead use this utils everytime you want the date format
