6 Replies Latest reply on Jul 30, 2010 2:01 AM by alexr@protech
    Splitting XML with Transform
    alexr@protech
      I am working on an application to create Work Orders using output. The host application sends a batch of Work Orders in XML format (generated using JFTRANS from the Central Migration). The XML contains the customer number. I use Transform to sort the incoming XML by customer number.The structure of the XML is like this:
      <File>
           <Record>
               <Header>
                     <custno>1234</custno>
                     <wonumber>001234<.wonumber>
                     <page>1</page
                </Header>
                <Detail>
                     <lineno>1</lineno>
                     <itemno>004444</itemno>
                </Detail>
                <Detail>
                     <lineno>2</lineno>
                     <itemno>005555</itemno>
                </Detail>
                <Header>
                </Header>
                <Detail>
                </Detail>
           </Record>
           <Record>
           </Record>
      </File>
      I tried to use the "Generate Multiple Streams" option of Output/generatePDFOutput to split the output by customer. Unfortunately, the "Generate Multiple Streams" only offers splitting on a "Record" level, not based on content. I need to generate a separate output file for each customer, which could have multiple Work Orders, each with 1 - n pages.
      The Foundation/Transform activity doesn't seem to have the functionality to define an XML split via XSLT.
      Has anyone done this before?
      Thank you!
