2 Replies Latest reply on Jul 28, 2010 11:02 PM by BhaskerChari
    Dynamic text in a dataGrid column?
    peteandrus Level 1
      i have a datagrid. i want to populate the first column with a different label depending on the row number.
      A good example of this would be
      Column 1 label
      Label 1
      Label 2
      Label 3
      Label 4
      I have these labels in an array, so i could access them if i had the row number.
      Anyone know how to do this?
      thanks!
        • 1. Re: Dynamic text in a dataGrid column?
          VRPDeveloper Level 3
          Your question is not clear...could u plz give proper example...what do u want ...
          Do you want to find row number?
          • 2. Re: Dynamic text in a dataGrid column?
            BhaskerChari Level 4
            Hi peteandrus,
            You can simply use the code snippet below to display the labels row wise....
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
               <mx:Script>
               <![CDATA[
                import mx.controls.Alert;
                  [Bindable]private var myAC:Array = [
                     {Column1:'Label 1', Column2:"Text 1"},
                     {Column1:'Label 2', Column2:"Text 2"},
                     {Column1:'Label 3', Column2:"Text 3"},
                     {Column1:'Label 4', Column2:"Text 4"}
               </mx:Script>
            <mx:DataGrid id="dataGrid" dataProvider="{myAC}" x="10" y="177" visible="true">
              <mx:columns>
               <mx:DataGridColumn  headerText="Column 1 label" dataField="Column1"/>
               <mx:DataGridColumn dataField="Column2" headerText="Column 2 label" />
              </mx:columns>
            </mx:DataGrid>
            </mx:Application>
            If you really want to find the row index based assignment you can try something using labelFunction for the DataGrid column...
            Something like below:
               <mx:Script>
               <![CDATA[
                import mx.controls.dataGridClasses.DataGridColumn;
            private var counter:int=-1;
                private function column1LabelFunction(item:Object, coulmn:DataGridColumn):String
                 var strLabel:String="";
                 counter++;
                 if(counter < myAC.length)
                  strLabel = myAC[counter].Column1;
              return strLabel;
               </mx:Script>
              <mx:columns>
               <mx:DataGridColumn  headerText="Column 1 label" labelFunction="column1LabelFunction"/>
              </mx:columns>
            </mx:DataGrid>
            </mx:Application>
            Bhasker Chari
