4 Replies Latest reply on Jul 29, 2010 7:09 AM by zeroskillz
    HtmlLoader and local content problems
    zeroskillz Level 3
      I'm having trouble with the HtmlLoader class and loading/displaying local content that contains flash files.
      As example, I load a local page with a flash video player and no video, but it's ffine if the file isn't local. Or a page with a flash google map, same thing, fine from web, nothing from local...
      Is there some method to allow this stuff?
      Thanks in advance!
      -Zeke
        • 1. Re: HtmlLoader and local content problems
          thilgen Level 4
          Was the SWF your HTMLLoader is loading published with the "Access network only" Local Playback Security option:
          General discussion with focus on Flash Professional:
          http://www.adobe.com/devnet/flash/articles/local_network_playback.html
          Ways to set this option when using Flex/FlashBuilder:
          http://blogs.adobe.com/flexdoc/2008/06/the_security_sandbox_in_flex_b.html
          Note: Use the custom compiler option, use-network=false, if you want to override the Flex Builder default compiler option. This would change the settings to local-with-filesystem
          Chris Thilgen
          AIR Engineering
          • 2. Re: HtmlLoader and local content problems
            zeroskillz Level 3
            No, but since you mentioned it, I tried it both ways...
            Doesn't seem to have any effect.
            As an example, I simply dragged an instance of the FLV component onto stage, set the source to a local file and published both ways. Loaded an html page with each and just get the skin, the vid never loads.
            Any thoughts?
            This is the code I'm testing with:
            var html:HTMLLoader = new HTMLLoader();
            html.width = 1600;
            html.height = 900;
            var urlReq:URLRequest = new URLRequest("flvtest.html");
            html.load(urlReq);
            addChild(html);
            Edited to add: If it's a matter of setting the local folders permissions or something, I can do that. This is for a kiosk app, so I have complete control over the 'client' computer...
            Edited further to add:
            I'm posting this in case someone runs into a similar problem and has the big 'DOH' moment I just had...
            The problem turned out to be using a relative path to load the video. My video URL was set to "vids/vid7.flv".
            Changing it to "C:/Program Files/myApplication/vids/vid7.flv" fixed the problem. Where this really got me was that I tried images loaded the same way without issue, so in my head there wasn't a relative path problem. Live and learn...
            Thanks for your help!
            Message was edited by: zeroskillz
            • 3. Re: HtmlLoader and local content problems
              zeroskillz Level 3
              Also, just in case, here is the html page code:
              <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
              <head>
              <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
              <title>flvtest</title>
              <body>FLV-Air Test<br>
                  <object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000"
                      codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=10,0,0,0"
                      width="956"
                      height="576"
                      id="flvtest"
                      align="middle">
                  <param name="allowScriptAccess" value="always" />
                  <param name="allowFullScreen" value="true" />
                  <param name="allowNetworking" value="all" />
                  <param name="movie" value="flvtest.swf" />
                  <param name="quality" value="high" />
                  <param name="bgcolor" value="#333333"/>
                  <embed
                      src="flvtest.swf"
                      quality="high"
                      bgcolor="#333333"
                      width="956"
                      height="576"
                      name="flvtest"
                      align="middle"
                      allowScriptAccess="always"
                       allowNetworking="all"
                      allowFullScreen="true"
                      type="application/x-shockwave-flash"
                      pluginspage="http://www.adobe.com/go/getflashplayer"
                  </object>
              </body>
              </html>
              • 4. Re: HtmlLoader and local content problems
                zeroskillz Level 3
                The problem turned out to be using a relative path for the video uri. Oddly, relative paths worked fine for images, so that threw me off.
