2 Replies Latest reply on Jul 29, 2010 5:36 AM by ArjanDs
    NumericStepper does not update dataProvider/ArrayCollection
    ArjanDs
      I created a editable nummeric stepper, like explained in the flex-in-a-week tutorial but somehow my dataprovider.. the arraycollection does not get updated with the new value and resets the value to the dataproviders value when the field looses focus.
      i have gone over the tut a view times, compared the code.. but i cant see why.
      the arraycollection is declared bindable
      [Bindable] private var provinces:ArrayCollection = new ArrayCollection;
      (being filled by a dataservice)
      below the code for the  datagrid:
                         <mx:DataGrid dataProvider="{provinces}" width="100%" height="100%" editable="true">
                              <mx:columns>
                                  <--snip removed two colums-->
                                  <mx:DataGridColumn
                                      headerText="Taxlevel"
                                      rendererIsEditor="true">
                                      <mx:itemRenderer>
                                          <fx:Component>
                                              <s:MXDataGridItemRenderer horizontalCenter="0">
                                                  <s:NumericStepper minimum="1" maximum="10"
        value="{data.TaxLevel}"/>
                                              </s:MXDataGridItemRenderer>
                                          </fx:Component>
                                      </mx:itemRenderer>
                                  </mx:DataGridColumn>
      any idea why the dataProvider is not being updated?
        • 1. Re: NumericStepper does not update dataProvider/ArrayCollection
          Flex harUI Adobe Employee
          You have to define the property to be pulled from the editor.  It defaults
          to 'text'.  You'll probably want something else.
                                      <mx:DataGridColumn
                                          editorDataField="nsValue"
                                          <mx:itemRenderer>
                                              <fx:Component>
          <fx:Script>
          Public function get nsValue():int { return ns.value };
          </fx:Script>
                                                      <s:NumericStepper id="ns"
                                              </fx:Component>
                                          </mx:itemRenderer>
          • 2. Re: NumericStepper does not update dataProvider/ArrayCollection
            ArjanDs Level 1
            thanks alex,
            At first it still wasnt updating and resetting the values to what is in the arraycollection.
            but including dataField="TaxLevel"  as well as  editorDataField="nsValue" in the DataGridColumn did the trick.
            below the code for others
            <mx:DataGridColumn editorDataField="nsValue" dataField="TaxLevel"
                                            <mx:itemRenderer>
                                                <fx:Component>
                                                    <s:MXDataGridItemRenderer>
                                                        <fx:Script>
                                                            <![CDATA[
                                                            public function get nsValue():int { return ns.value };
                                                        </fx:Script>
                                                        <s:NumericStepper id="ns" minimum="1" maximum="10"
                                                </fx:Component>
                                            </mx:itemRenderer>
