1 Reply Latest reply on Aug 6, 2007 2:09 AM by chris.huston.t10
    Problem Integer and Float
    maaz_sun_james
      Hi all,
      i am having a problem in comparing a integer with a number (float and double).
      can any one help me in showing how we can Differentiate a integer and float or double in flex.
      Maaz
        • 1. Re: Problem Integer and Float
          chris.huston.t10 Level 3
          You can check what type a value is with the 'is' operator.
          if (someVar is Number) do something;
          else if (someVar is uint) do something else;
          You can compare them with standard comparison operators: ==, <, >
          You can convert a Number to an int or other type:
          var someInt:int = int(someNumber);
          This conversion will simply truncate the decimal portion of the Number. If you need rounding, you will need to use the Math round function.
          Vygo
