1. Re: File/folder organization on your drive
marinuse Jul 29, 2010 6:16 AM (in response to EckleySP)You're missing Lightroom
That's positively the best piece of software for keywording and filtering for keywords.In Bridge if you press Ctrl+F (Windows) or Cmd+F (Mac) you get a search box in which you can define a set of search strings.
That's the most specific way you can search within Bridge.
2. Re: File/folder organization on your drive
Greg Moffatt Jul 29, 2010 6:16 AM (in response to EckleySP)Perhaps because I spent most of my working life as an engineering designer, and then as a software designer/programmer I'm used to working with file number/names and a decent drawing/file retreival system, so I have all mine in one folder. Yes it gets big, but using Bridge with keywords and it's filter, it's pretty simple to find a file. I have previously moved raw and psd files to separate folders to speed up search times when I was using CS2, just leaving small jpg in the main folder. However, having just moved to CS5 speed is no longer a problem. I reckon they may all go back together.
3. Re: File/folder organization on your drive
Curt Y Jul 29, 2010 6:58 AM (in response to EckleySP)Search works down the directory tree from the start point. So choose your start point high enougth so folders you want to search will be included. This assumes of course these sub folders are indexed.
