• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Code to change state by time & day
New Here ,
Jul 29, 2010 Jul 29, 2010
Hi There,
I'm new to working with Flash Builder and have what I think is an easy question.
I work for a not-for-profit radio station and am creating an application that displays the personality that's on-air.  For example, Mon-Fri from 6a-10a I'd like it to show the morning show state, etc...  But on weekends show something generic.  I already have an XML data service that's working and displaying artist & title info... But for the life of me can't figure out how to change states by time.  I've googled and can only find state changes by button clicks, which I already knew.  Any help MUCH appreciated - thanks!
Views
471
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
Jul 30, 2010 Jul 30, 2010
Hi Izzy_Knight,
It depends on the time you would like this to happen. The easiest way would be to create a creationComplete event handler for the application (or the component you are creating) and then check the current time (using the Date class). On your desired times, change the state with setCurrentState() accordingly.
If you would like this to happen overtime, as-it-runs, then my suggestion would be to create a Timer object with 60000 milliseconds for example and make the same if statements there as well (you could also call, from inside your timer event handler, the initially called creationComplete handler with null as an input event).
Hope this makes sense.
Ioannis
Votes
Translate
Translate
Report
Report
New Here ,
Ioannis-bels,
I'll be sure to give this a shot and let you know if this works.  Thanks!
Votes
Translate
Translate
Report
Report
Contributor ,
Aug 10, 2010 Aug 10, 2010
LATEST
You could use a Timer and TimerEvent.
[http://livedocs.adobe.com/flex/3/langref/flash/utils/Timer.html] and [http://livedocs.adobe.com/flex/3/langref/flash/events/TimerEvent.html]
var myTimer:Timer=new Timer(delay,repeatCount)
myTimer.addEventListener(TimerEvent.TIMER,functionThatWillChangeStates)
Hope this helps,
Balakrishnan V
Votes
Translate
Translate
Report
Report
