2 Replies Latest reply on Jul 30, 2010 5:52 PM by celebritymusic
    slashes get added when writing text file - AS3
    celebritymusic Level 1
      Hi
      I'm using flash and php to write or overwrite a text file (an xml file).  I have text strings that contain the xml data, which then get parsed by the php file.
      It works fine.  However, I notice that the header in the XML file <?xml version='1.0' encoding='utf-8'?> get's replaced with <?xml version=\'1.0\' encoding=\'utf-8\'?>
      Why would slashes get added?
      Here's the text string code in AS3...
      var Everything:String = "<?xml version='1.0' encoding='utf-8'?>\n\n<XML>\n\n"+g1.data.layoutFontsGroup+"\n\n\n        </XML>
      and my php code...
      <?php
         //Capture data from Flash variable, and add it to "$everything"
         $everything = $_POST['saveThisXML'];
         //Make one big string in a format Flash understand
         $toSave = $everything;
         //Open a file in write mode
         $fp = fopen("test.xml", "w");
         if(fwrite($fp, $toSave)) echo "writing=Ok";
         else echo "writing=Error";
         fclose($fp);
      Thanks for your help on this one.
      Shaun
