2 Replies Latest reply on Aug 1, 2010 1:16 PM by BigG2009
    Back to front Form
    BigG2009 Level 1
      Hi There
      I am fairly new to PHP and have picked up a small project to make alterations to a Order Form.  The site can be found at http://www.brighton-company-formations.co.uk/ordering.php
      The problem exists when I get to step 5 in the process - if you wnt to get this far you need to put some dummy text in the form to allow you to progress to this stage.
      I have attached the code for the page below and would appreciate some assistance from anyone that might be able to help.
      Thanks in advance
      G
      <?php  include 'calculate-amount.php'; ?>
      <form action="" method="post">
      <p>
        Please review the details below and make your payment securely online if the details are correct.
      </p>
      <p>
        <strong>
          The total order amount is: £<?php echo number_format((calculate_amount()/100.0), 2); ?> including VAT.
        </strong>
        This is calculated from your chosen package, postage method, whether you are using our
        service address facility and any extra copies of articles of association you have added.
      </p>
      <p>
        Please press the Back button below if you need to make any changes.
      </p>
              <fieldset>
              <legend>Your order details</legend>
                  <ul>
          <?php
          $excludes = array('Next','Next X','Next Y','stage1','stage2','stage3','stage4','stage5','cd_in_eea','shipping_address_same_as_reg istered_address','billing_address_same_as_registered_address');
          foreach ($_POST as $key=>$value){
              $label = ucwords(str_replace('_',' ',$key));
              $val = ucwords(str_replace('_',' ',$value));
            echo !in_array($key,$excludes)&&!empty($value)&& strpos($label,'Selectaddress') === FALSE?"<li>$label: $val</li>":'';
      </ul>
                      <input name="Back" type="submit"  class="cancel"   value="Back" align="left" width="54" height="20" border="0" />
                      <input name="Next" type="submit"   value="Next" align="left" />
              <input type="hidden" name="stage5" value="1" />
              <?php foreach($_POST as $name => $value) { if(!empty($value)) echo "<input type=\"hidden\" name=\"$name\" value=\"$value\" />" ;} ?>
          </fieldset>
      </form>
