1 Reply Latest reply on Aug 14, 2010 3:51 PM by Mark Robbins 312
    Crossfade Transition
    deross Level 1
      In Flash Builder 4, I would like to have a crossfade transition so that everything in the group container in my base state crossfades to everything in my border container in the second state.
      For simplicity, I will name these:
      base viewstate = "state_1"
      second viewstate = "state_2"
      group container in base viewstate = "gc_1"
      border container in second viewstate = "bc_2"
      PS I used a border container in the second view state because I use a fullscreen backgroud image.
        • 1. Re: Crossfade Transition
          Mark Robbins 312
          AFAIK, states is not the way to accomplish this because you need both components visible during the transition. What you need to do is set up a parallel effect with two fades in it, one for each component.
          <mx:Parallel id="fadeToGroup2">
            <mx:Fade target="group1" alphaFrom="1.0" alphaTo="0.0" duration="1000" effectComplete="group1.visible=false;" effectStart="group2.alpha=0.0;group2.visible=true;"/>
            <mx:Fade target="group2" alphaFrom="0.0" alphaTo="1.0" duration="1000"/>
          </mx:Parallel>
          <<and the opposite of the above>>
          Then both groups will have to overlay each other, with one group visible, then click="fadeToGroup2.play()"
          Basically.
