0 Replies Latest reply on Jul 31, 2010 7:56 AM by davidqxo
    Can't upgrade to AIR 2. Same old "administrator" error.
    davidqxo
      On Windows XP SP3, attempting to upgrade from Pandora Player, Adobe AIR 1.5.3.9130 to 2.0.2.12610 I get this error.
      An error occurred while installing Adobe AIR. Installation may not be allowed by your administrator.
      I download the installer and try running directly with same results.
      I delete:
      c:\Documents and Settings\David\Local Settings\Application Data\Adobe\AIR\
      and remove related registry entries using CCleaner. [The recommended Windows Installer Cleanup Utility miscuu2.exe seems to no longer be available.] Same results. Here's the log.
      [2010-07-31:09:37:56] Performing runtime install
      [2010-07-31:09:37:56] UI SWF load is complete
      [2010-07-31:09:37:58] UI initialized
      [2010-07-31:09:37:58] starting user confirmation
      [2010-07-31:09:37:58] Version of this installer: 2.0.2.12610
      [2010-07-31:09:37:58] Installation type: new
      [2010-07-31:09:38:03] starting install
      [2010-07-31:09:38:03] Scheduling runtime installation operations
      [2010-07-31:09:38:03] Active AIR product GUID is {A2BCA9F1-566C-4805-97D1-7FDC93386723}
      [2010-07-31:09:38:03] Scheduling an MSI install operation
      [2010-07-31:09:38:03] Beginning runtime installation
      [2010-07-31:09:38:03] Beginning install
      [2010-07-31:09:38:03] Installing c:\docume~1\david\locals~1\temp\air68d.tmp\setup.msi
      [2010-07-31:09:38:03] Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1601" errorID=0]
      [2010-07-31:09:38:03] Rolling back install of c:\docume~1\david\locals~1\temp\air68d.tmp\setup.msi
      [2010-07-31:09:38:03] Rollback due to error complete
      [2010-07-31:09:38:03] error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1601" errorID=0]
      [2010-07-31:09:38:03] runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1601" errorID=0]
      [2010-07-31:09:38:07] begin quitting
        --David
