5 Replies Latest reply on Aug 3, 2007 7:00 AM by Newsgroup_User
    Templated final works in DW8, but not DWCS3
    rossmgreenberg
      When I access the template at this address:
      http://www.bovinaupchurch.org/Templates/xyz.dwt with Dreamweaver8, no
      problem whatsoever.
      However when I try to access it using Dreamweaver CS3 I get only the
      "spackle" background with nothing else. Other templated sites with other
      templates work without a problem; so what is so peculiar about this
      template?
      This particular site has been up and operational for a few years. I cut
      this template only as an example of my current problem.
      What is the problem and how do I resolve it? Is it a problem with the site,
      the template, CS3 or the phase of the moon?
      Thanks!
      Ross
        • 1. Re: Templated final works in DW8, but not DWCS3
          Level 7
          On Fri, 3 Aug 2007 11:27:38 +0000 (UTC), "rossmgreenberg"
          > problem whatsoever.
          > template?
          > Thanks!
          > Ross
          Sorry I can't pin point it - but as the code is a mixture of html /
          xhtml - some upper case some lower case - it is not so easy to read.
          Maybe a good idea to look at this -
          http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fwww.bovinaupchurch.org%2FTemplate s%2Fxyz.dwt
          as you have lots of xhtml already - - just convert the rest and put in
          a xhtml DOCTYPE and it might be easier to pin point the problem.
          in Dw File | convert will do the lot for you.
          It will put in the Doc type,
          correct errors such as
          changing this
          <script language="JavaScript">
          to
          <script language="JavaScript" type="text/javascript">
          ~Malcolm N....
          • 2. Re: Templated final works in DW8, but not DWCS3
            rossmgreenberg Level 1
            You suggestions make good sense: I sort of inherited this template and your has a lot of things that need to be fixed up!
            However I did not expect that fixing up this template -- and who knows what else? -- be a requirement in order for me to use DW CS3!!
            On until I fix up, CS3 is entirely useless to me -- I can not even saying that pages that I was able to see/modify/etc. in DW8.
            Is there a "backwards compatibility mode"?
            Ross
            • 3. Re: Templated final works in DW8, but not DWCS3
              (Please forgive me for some of the senseless things that I may have posted: I use Dragon Naturally Speaking voice recognition, which is not 100% accurate, and I post sometimes before I correct what I call "speako's" as opposed to "typo's")
              • 4. Re: Templated final works in DW8, but not DWCS3
                Level 7
                CS3 is a stickler for valid code. If your code is broken, CS3's display
                will be broken too. And it should be.
                Murray --- ICQ 71997575
                Adobe Community Expert
                (If you *MUST* email me, don't LAUGH when you do so!)
                http://www.dreamweavermx-templates.com - Template Triage!
                http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
                http://www.dwfaq.com - DW FAQs, Tutorials & Resources
                http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
                "rossmgreenberg" <webforumsuser@macromedia.com> wrote in message
                news:f8v92k$t02$1@forums.macromedia.com...
                > your has
                > what
                > that
                > Ross
                • 5. Re: Templated final works in DW8, but not DWCS3
                  Level 7
                  On Fri, 3 Aug 2007 13:03:16 +0000 (UTC), "rossmgreenberg"
                  No of course not - but having good valid code is a very good starting
                  point and makes it easier to maintain.
                  As Murray says Dw CS3 is rather stricter - and that in my humble
                  opinion is a good thing, because then you will have less trouble
                  making the site compatible with various browsers.
                  You can still use Dw 8 to tidy it up and then try again with Dw CS3.
                  When installing Dw CS3 - you can keep Dw8 on the PC - but you can't
                  use both at once.
                  ~Malcolm N....
