22 Replies Latest reply on Aug 5, 2010 9:41 AM by celronart
    Install Adobe Flash player 10.1 popup will not stop popping up!
    Bobback1
      I have been trying for 3 weeks to rid my computer of the "install adobe flash player" popup. I have installed and  uninstalled Flash Player as advised many times and contacted every forum I can find.  I don't believe I should have to pay a fee to remove something Adobe installed on my computer without my knowledge (the popup reminder), The popup appears every time I start a program that may use it at least 15-20 times a day. I'm using windows XP Pro service pack 3. I use AOL and IE ver 8 for most of my browsing.  Thanks for any assistance.
        • 1. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
          pwillener Level 8
          Not sure if that pop-up is genuine - are you sure that your computer is free from malware?
          Can you see the Flash animation at http://www.adobe.com/software/flash/about/ and is there a version information beneath it?
          What files do you have in folder C:\Windows\system32\Macromed\Flash ?
          • 2. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
            Bobback1 Level 1
            First of all thanks for your help.
            I have run Malwarebytes anti malware scan both "quick" and deep modes, Trojan remover,CC cleaner,ad-aware, and glary utilities. No hits
            adobe site says install successful shows version 10.1.53.64
            re What files do you have in folder C:\Windows\system32\Macromed\Flash ?
            Flash player trust folder
            Flash10h.ocx
            Flashinstall .log
            Flashutil10h-_ActiveX.exe
            Flashutil10h_ActiveXdll.dll
            • 3. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
              pwillener Level 8
              Go to http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager05.htm l and uncheck "Notify me if an update to Adobe Flash Player is available."
              Does the pop-up still appear after this?
              • 4. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
                Bobback1 Level 1
                Went to site (again)  unchecked box (again)  no luck  rebooted went back to site, box was still unchecked. Popup continues. Thanks for your suggestions. Still have problem.
                • 5. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
                  pwillener Level 8
                  Can you show us a screenshot of that pop-up?
                  • 7. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
                    eidnolb onlyone Level 5
                    Hi Pat, even tho this screenshot is different, many users will receive the message from youtube and other sites to update Flash Player when they have already done so. But the Shockwave Flash Object is not Enabled or Installed. Perhaps it may be that. I didn't see that he could see the animation at the test site. Just a thot. I have not seen this very often, usually it is just the message.
                    eidnolb
                    • 8. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
                      Bobback1 Level 1
                      I did see the annimation on the test site. As always thanks for staying with this..  Bob
                      • 9. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
                        Hi, thanks for confirming that. What is causing this is hard to tell. Pat has already went thru what it could be and so have you. Are you also receiving other pop ups, perhaps from AOL? Anti-Virus add ons can cause strange things to happen also. Some can conflict with the Shockwave Flash Object that is the Control for the Flash Player files, some conflict with the browser itself and others can conflict with each other.
                        What Anti-Virus program do you have Installed and did you turn off all of the components when you ran Malwarebytes?
                        If you didn't, then there could have been a conflict. Just asking about this, since I have seen these things happen before.
                        Just something else to check. Perhaps Pat will have another idea.
                        eidnolb
                        • 10. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
                          Bobback1 Level 1
                          *What Anti-Virus program do you have Installed and did you turn off all of the components when you ran Malwarebytes?*
                          *If you didn't, then there could have been a conflict. Just asking about this, since I have seen these things happen before.*
                          useing Trend Micro did not turn off for Malware scan will do so now. I'll run a full scan  takes 2 hours  so I'll check back in in the morning. Thanks, Bob
                          • 11. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
                            Hi, ok, probably a good idea, just another check. This site has some info on TM. You most likely know all of this, but thot I'd post it just in case. It seems Anti-Virus programs are always adding new components and I'm not that familiar with TM.
                            http://www.ehow.com/how_5772247_disable-trend-micro-antivirus-firewall.html
                            This site is interesting and not just limited to TM.
                            eidnolb
                            • 12. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
                              pwillener Level 8
                              Thank you for the screenshot.  This is very curious; this should not pop up automatically - this is the panel we see when we manually launch the FP installer.
                              When you see that panel again next time, can you check the Task Manager (Processes tab) if you see something 'adobe...' and/or 'install_flash_player...' running?
                              • 13. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
                                Bobback1 Level 1
                                I think using your suggestion we've found a clue.. started task manager determined following app line was appearing when popup popped...FP_AX_CAB_INST..
                                ran search for file and found many copies in perfetch and a text log "SetupAPILog" which probably explains whats going on. I will attempt to send in this message
                                I also ran a "regedit find" found several "keys" with the file name and the word conflict mostly so far in downloaded program files (approx 500)  approximately 100 referenced them selves to flash player install.
                                I will copy log to you below and wait for next suggestion  hope this helps.
                                here's apisetup log sorry its so long
                                [SetupAPI Log]
                                OS Version = 5.1.2600 Service Pack 3
                                Platform ID = 2 (NT)
                                Service Pack = 3.0
                                Suite = 0x0100
                                Product Type = 1
                                Architecture = x86
                                [2010/08/01 21:29:40 9924.14]
                                #-198 Command line processed: "C:\Program Files\AOL 9.1\waol.exe"
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD1.tmp\a text fileER.exe" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.492\FP_AX_CAB_INSTALLER.exe".
                                #E361 An unsigned or incorrectly signed file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD1.tmp\FP_AX_CAB_INSTALLER.exe" will be installed (Policy=Ignore). Error 0x800b0110: The certificate is not valid for the requested usage.
                                [2010/08/01 21:29:43 9924.15]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD1.tmp\swflash.inf" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.492\swflash.inf".
                                #E361 An unsigned or incorrectly signed file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD1.tmp\swflash.inf" will be installed (Policy=Ignore). Error 0x800b0100: No signature was present in the subject.
                                [2010/08/02 04:24:33 6044.3]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD1.tmp\FP_AX_CAB_INSTALLER.exe" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.493\FP_AX_CAB_INSTALLER.exe".
                                [2010/08/02 04:24:37 6044.4]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD1.tmp\swflash.inf" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.493\swflash.inf".
                                [2010/08/02 04:46:28 12280.3]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD1.tmp\FP_AX_CAB_INSTALLER.exe" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.494\FP_AX_CAB_INSTALLER.exe".
                                [2010/08/02 04:46:48 12280.4]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD1.tmp\swflash.inf" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.494\swflash.inf".
                                [2010/08/02 05:47:42 10728.3]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD1.tmp\FP_AX_CAB_INSTALLER.exe" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.495\FP_AX_CAB_INSTALLER.exe".
                                [2010/08/02 05:47:49 10728.4]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD1.tmp\swflash.inf" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.495\swflash.inf".
                                [2010/08/02 08:36:46 10892.3]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD1.tmp\FP_AX_CAB_INSTALLER.exe" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.496\FP_AX_CAB_INSTALLER.exe".
                                [2010/08/02 08:39:13 10892.15]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD1.tmp\swflash.inf" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.496\swflash.inf".
                                [2010/08/02 08:39:53 4068.3]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD1.tmp\FP_AX_CAB_INSTALLER.exe" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.497\FP_AX_CAB_INSTALLER.exe".
                                [2010/08/02 09:06:36 5276.3]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\FP_AX_CAB_INSTALLER.exe" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.498\FP_AX_CAB_INSTALLER.exe".
                                #E361 An unsigned or incorrectly signed file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\FP_AX_CAB_INSTALLER.exe" will be installed (Policy=Ignore). Error 0x800b0110: The certificate is not valid for the requested usage.
                                [2010/08/02 09:06:58 5276.4]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\swflash.inf" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.498\swflash.inf".
                                #E361 An unsigned or incorrectly signed file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\swflash.inf" will be installed (Policy=Ignore). Error 0x800b0100: No signature was present in the subject.
                                [2010/08/02 10:46:16 2456.3]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\FP_AX_CAB_INSTALLER.exe" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.499\FP_AX_CAB_INSTALLER.exe".
                                [2010/08/02 10:46:29 2456.15]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\swflash.inf" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.499\swflash.inf".
                                [2010/08/02 11:54:00 1076.14]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\FP_AX_CAB_INSTALLER.exe" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.500\FP_AX_CAB_INSTALLER.exe".
                                [2010/08/02 11:54:05 1076.15]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\swflash.inf" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.500\swflash.inf".
                                [2010/08/02 12:34:07 2908.3]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\FP_AX_CAB_INSTALLER.exe" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.501\FP_AX_CAB_INSTALLER.exe".
                                [2010/08/02 12:35:53 2908.15]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\swflash.inf" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.501\swflash.inf".
                                [2010/08/02 13:13:53 4804.3]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\FP_AX_CAB_INSTALLER.exe" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.502\FP_AX_CAB_INSTALLER.exe".
                                [2010/08/02 13:14:03 4804.4]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\swflash.inf" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.502\swflash.inf".
                                [2010/08/02 19:57:28 6108.14]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD1.tmp\FP_AX_CAB_INSTALLER.exe" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.503\FP_AX_CAB_INSTALLER.exe".
                                [2010/08/02 20:38:02 3284.3]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\FP_AX_CAB_INSTALLER.exe" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.504\FP_AX_CAB_INSTALLER.exe".
                                [2010/08/02 20:38:13 3284.4]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\swflash.inf" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.504\swflash.inf".
                                [2010/08/03 00:18:07 2428.14]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\FP_AX_CAB_INSTALLER.exe" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.505\FP_AX_CAB_INSTALLER.exe".
                                [2010/08/03 00:18:14 2428.15]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\swflash.inf" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.505\swflash.inf".
                                [2010/08/03 00:21:40 2468.3]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\FP_AX_CAB_INSTALLER.exe" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.506\FP_AX_CAB_INSTALLER.exe".
                                [2010/08/03 00:23:10 2468.4]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\swflash.inf" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.506\swflash.inf".
                                [2010/08/03 00:26:08 804.3]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\FP_AX_CAB_INSTALLER.exe" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.507\FP_AX_CAB_INSTALLER.exe".
                                [2010/08/03 00:27:13 804.4]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\swflash.inf" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.507\swflash.inf".
                                [2010/08/03 00:33:18 3496.3]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\FP_AX_CAB_INSTALLER.exe" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.508\FP_AX_CAB_INSTALLER.exe".
                                [2010/08/03 00:36:48 3496.4]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\swflash.inf" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.508\swflash.inf".
                                [2010/08/03 00:47:55 3432.3]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\FP_AX_CAB_INSTALLER.exe" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.509\FP_AX_CAB_INSTALLER.exe".
                                [2010/08/03 00:48:06 3432.4]
                                #-024 Copying file "C:\DOCUME~1\Bob\LOCALS~1\Temp\ICD2.tmp\swflash.inf" to "C:\WINDOWS\Downloaded Program Files\CONFLICT.509\swflash.inf".
                                • 14. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
                                  pwillener Level 8
                                  This is very curious (did I say that before?)...  The error(s) we are seeing in this log seems somehow to be related to the AOL browser (which I do not know at all).
                                  I know you have mentioned before that you have uninstalled and reinstalled many times, but I would like to try one more time a clean uninstall and install of the FP ActiveX control:
                                  • download the FP uninstaller from http://kb2.adobe.com/cps/141/tn_14157.html (save to disk);
                                  • download this MSI installer http://www.adobe.com/go/full_flashplayer_win_msi (save to disk);
                                  • close all browser windows (also any messenger programs) and run the downloaded uninstaller;
                                  • restart windows;
                                  • temporarily disable your antivirus software;
                                  • with no browser windows or messengers running, run the downloaded MSI installer.  You should get the same install panel that you posted earlier; check the checkbox next to "I have read and agree..." the click the INSTALL button.
                                  When the installation is complete, can you check file FlashInstall.log in the C:\Windows\system32\Macromed\Flash folder?  Any errors in there?
                                  • 15. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
                                    Bobback1 Level 1
                                    yes error see end of log
                                    =O====== M/10.1.53.64 2010-08-03+08-15-23.906 ========
                                    0000 [I] 00000010 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10h_ActiveX.exe -uninstall activex -msi
                                    0001 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                                    0002 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10h_ActiveX.exe 5
                                    0003 [I] 00000018
                                    0004 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10h_ActiveX.exe 5
                                    0005 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                                    0006 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
                                    0007 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                                    0008 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
                                    0009 [W] 00001021
                                    0010 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10h_ActiveX.exe 5
                                    0011 [I] 00000012
                                    =X====== M/10.1.53.64 2010-08-03+08-15-24.156 ========
                                    =O====== M/10.1.53.64 2010-08-03+08-15-17.984 ========
                                    0000 [I] 00000010 "C:\Documents and Settings\Bob\Desktop\uninstall_flash_player.exe" -force
                                    0002 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
                                    0003 [W] 00001017
                                    0004 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                                    0005 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
                                    0006 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                                    0009 [W] 00001021
                                    0010 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                                    0011 [W] 00001018
                                    0012 [W] 00001036 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
                                    0013 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
                                    0014 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
                                    0015 [W] 00001019
                                    0016 [W] 00001020
                                    0017 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                                    0018 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
                                    0019 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                                    0020 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                                    0021 [W] 00001021
                                    0022 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
                                    0023 [W] 00001036 Software\Opera Software/Last CommandLine 2
                                    0024 [W] 00001036 Software\Opera Software/Last CommandLine 2
                                    0025 [W] 00001036 Software\Opera Software/Plugin Path 2
                                    0026 [W] 00001036 Software\Opera Software/Plugin Path 2
                                    =X====== M/10.1.53.64 2010-08-03+08-16-26.609 ========
                                    =O====== M/10.1.53.64 2010-08-03+08-30-32.734 ========
                                    0000 [I] 00000010 "C:\DOCUME~1\Bob\LOCALS~1\Temp\InstallAX.exe" -install activex -msi
                                    0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/10.0 2
                                    0002 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                                    0003 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash10h.ocx
                                    0004 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10h_ActiveX.exe
                                    0005 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10h_ActiveX.dll
                                    =X====== M/10.1.53.64 2010-08-03+08-30-36.437 ========
                                    =O====== M/10.1.53.64 2010-08-03+08-32-21.875 ========
                                    0000 [I] 00000010 "C:\WINDOWS\Downloaded Program Files\CONFLICT.513\FP_AX_CAB_INSTALLER.exe" /RegServer
                                    0002 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash10h.ocx
                                    0003 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10h_ActiveX.exe
                                    0004 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10h_ActiveX.dll
                                    =X====== M/10.1.53.64 2010-08-03+08-32-34.437 ========
                                    • 16. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
                                      pwillener Level 8
                                      I don't see any error(s), just [I] and [W] messages.  Which one do you see as an error?  To me it looks like a successful installation.
                                      Does Flash Player work?
                                      Do you still get these unwanted pop-ups?
                                      • 17. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
                                        Bobback1 Level 1
                                        I'm sorry Error was an incorrect word.I was referring to 0000 [I] 00000010 "C:\WINDOWS\Downloaded Program Files\CONFLICT.513\FP_AX_CAB_INSTALLER.exe" /RegServer re the conflict message.
                                        yes it works and yes the popups continue
                                        • 18. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
                                          pwillener Level 8
                                          This really seems to be specific to AOL; I found this other topic http://forums.adobe.com/message/2910121 (unresolved).
                                          The question is: where does that pop-up come from - what triggers it?  Is it something that is issued during startup?
                                          Can you check msconfig if there are any startup items that might indicate something Adobe or FP?
                                          Also, are there any AOL forums that may address AOL browser / add-on issues?  (Where you could search for FP_AX_CAB_INSTALLER.exe)
                                          • 19. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
                                            Bobback1 Level 1
                                            OK ! using your thought "This really seems to be specific to AOL; , "  I uninstalled AOL completely, and installed a later version (ver 9.5). It appears that the problem is gone for now. I will let you know if it returns. I can't tell you how much I appreciate all of your assistance.
                                            Thank you again!
                                            • 20. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
                                              pwillener Level 8
                                              Thank you for the feedback - good to know that there is a way to solve this.
                                              • 21. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
                                                Bobback1 Level 1
                                                Thanks once again for all your help!
                                                  Good Luck, Bob
                                                • 22. Re: Install Adobe Flash player 10.1 popup will not stop popping up!
                                                  celronart
                                                  Hi, It seems AOL and the INSTALL FP POP-UP is my problem too. If I click anywhere on the AOL homepage at startup , the FP POP-UP goes away.
                                                  Ofcourse, with AOL it's just one or many annoying POP-UPS!  I would love to get rid of it anyway. There must be more AOL addicts infected by this carp? Good Luck!
                                                  Celronart
