5 Replies Latest reply on Sep 12, 2010 11:59 AM by John T Smith
    Rendering questions
    soxenme
      Premiere Elements 8.01 input w/editing ACSHD.MTS and will output to bluray disk.....
      1.  Would someone please give me the definitive answer:  Does background rendering improve the quality of the finished product - I've Googled this and          found conflicting answers.
      2.  Wanting the best quality of bluray disk as the output I chose the option for background rendering - WHY does it have all those red line (indicating
           rendering) on the timeline EVERY single time I REOPEN a saved project???   So it wants to render AGAIN before I can do anymore editing...(?)
      Thanks in advance for your response.
        • 1. Re: Rendering questions
          the_wine_snob Level 9
          Rendering is just to provide the best possible playback results, and if you have smooth enough playback, you do not need to do it. It creates files just for playback and takes some time, plus adds files to the HDD. If you DO need to Render for smooth playback, you can then delete those Render files, when done.
          As for Background Rendering, this was a recent addition. The concept is that one can have Rendering done, while editing. However, what usually happens is that the resources required to do the Rendering interferes with the process of editing.
          It was incorporated into an earlier version of Pinnacle, and I think that almost every user of that program turned it off, at least by the responses in that forum at that time.
          • 2. Re: Rendering questions
            In fact, once you update to version 8.01, I believe, Background Rendering is turned off by default. I recommend you keep it off. It's way too intrusive.
            But it sure doesn't hurt to render your project manually as you're working on it (by pressing the Enter key). As Hunt says, it doesn't much effect your output -- but it can greatly improve the performance of the program as you're editing it. (It can also alert you to possible rendering problems -- which might otherwise cause problems when you try to output your file.)
            The problem with your rendered files needing re-rendered every time you re-open your project has a couple of possible causes (depending on where you're storing your project files). But most people find it is remedied by updating to the latest version of Quicktime on Apple.com.
            • 3. Re: Rendering questions
              sidlerm
              Hello,
              I've got the same problem about rendering, I must run it every time I open my project, which is quite huge, so it takes hours. I've got the last version of Quicktime, any other solution ? I can't turn the rendering off, otherwise, the image doens't run smoothly and I can't do my cut... Working with AVCHD. 4 GB RAM, Intel Core duo 3.33 Mhz... eveything should be fine but it isn't.
              Thanks a lot.
              Marianne
              • 4. Re: Rendering questions
                Welcome to the forum.
                With a Duo-Core CPU, you will likely never get really good playback. Most feel that a Quad-Core is the minimum, while many feel that only a fast i7 will be adequate for AVCHD source footage.
                Now, why you are loosing the link to the Render files is a mystery. Where are your Scratch Disks located?
                • 5. Re: Rendering questions
                  >Intel Core duo
                  AVCHD is very CPU intensive (not so much hard drive transfer speed) and effective use requires a quad core or i7
                  Convert AVCHD to HDV http://forums.adobe.com/thread/390605?tstart=0
                  or use Cineform Neo Scene http://www.cineform.com/neoscene/
