4 Replies Latest reply on Dec 13, 2010 8:41 AM by lavum
    Changing List's item renderer and layout causes exception
    tehxike1 Level 1
      I have buttons in my UI to switch a list between a tile view (thumbnails) and a list view (details).
      This code works:
           var layout:TileLayout = new TileLayout();
           resultsList.layout = layout;
           resultsList.itemRenderer = new ClassFactory(MediaTileRenderer);
      This code doesn't:
           var layout:VerticalLayout = new VerticalLayout();
           resultsList.itemRenderer = new ClassFactory(MediaItemRenderer);
      It's not the item renderer's fault, I can use the tile renderer again in the second block of code and it will still explode.  If I swap the VerticalLayout for a TileLayout, it works fine.  HorizontalLayout explodes.
      The exception is occurring in LinearLayoutVector/remove (541):
      Error: invalidIndex
      at spark.layouts.supportClasses::LinearLayoutVector/remove()[E:\dev\4.x\frameworks\projects\ spark\src\spark\layouts\supportClasses\LinearLayoutVector.as:541]
      at spark.layouts::VerticalLayout/elementRemoved()[E:\dev\4.x\frameworks\projects\spark\src\s park\layouts\VerticalLayout.as:1311]
      at spark.components::DataGroup/http://www.adobe.com/2006/flex/mx/internal::itemRemoved()[E:\dev\4.x\frameworks\projects\s park\src\spark\components\DataGroup.as:1580]
      at spark.components::DataGroup/removeRendererAt()[E:\dev\4.x\frameworks\projects\spark\src\s park\components\DataGroup.as:625]
      at spark.components::DataGroup/removeAllItemRenderers()[E:\dev\4.x\frameworks\projects\spark \src\spark\components\DataGroup.as:642]
      at spark.components::DataGroup/set itemRenderer()[E:\dev\4.x\frameworks\projects\spark\src\spark\components\DataGroup.as:446 ]
      at spark.components::SkinnableDataContainer/set itemRenderer()[E:\dev\4.x\frameworks\projects\spark\src\spark\components\SkinnableDataCon tainer.as:420]
      Does anyone know why this doesn't work?  It seems like a fairly common idea- using a single list and toggling between different view modes.
