4 Replies Latest reply on Jun 22, 2012 4:20 PM by drkstr_1
    Anyway to clear CallResponder returned valueobjects for GC?
    RobX82
      Background:
      Flex 4.1
      PHP backend through Zend framework
      Utilizing the paging functionality new in Flex 4
      I have a search interface setup in Flex that the user can define some values and get a return set shown in the grid.  The problem is when profiling it would appear that the any previous searches returned valueobjects never get garbage collected.
      So I was wondering if there is some way to clear/mark these valueobjects for garbage collection.
        • 2. Re: Anyway to clear CallResponder returned valueobjects for GC?
          gfbaggio9 Level 1
          I am looking for the same think
          Have you found a solution?
          • 3. Re: Anyway to clear CallResponder returned valueobjects for GC?
            RobX82 Level 1
            No, I never did.  We have since moved away from all Flex development.
            • 4. Re: Anyway to clear CallResponder returned valueobjects for GC?
              drkstr_1 Level 4
              Here is my base service class which is intended to keep the memory footprint low. Just Extend it into a specific service implementation and call disconnect() after any return result.
              public class AbstractRemoteService
                        public function AbstractRemoteService()
                        public var destination:String = "";
                        private var _remoteObject:RemoteObject;
                        protected function get remoteObject():RemoteObject
                                  if(!_remoteObject)
                                            _remoteObject = new RemoteObject(this.destination);
                                  return _remoteObject;
                        public function disconnect():void
                                  if(!_remoteObject)
                                            return;
                                  _remoteObject.disconnect();
                                  _remoteObject = null;
              Example Implementation:
              public class ContentService extends AbstractRemoteService implements IContentService
                        public function ContentService()
                                  super();
                                  this.destination = "content_service";
                        public function beginSection(classNumber:int, section:int):AsyncToken
                                  return this.remoteObject.beginSection(classNumber, section);
                        public function completeSection(classNumber:int, section:int):AsyncToken
                                  return this.remoteObject.completeSection(classNumber, section);
                        public function loadAssignments():AsyncToken
                                  return this.remoteObject.loadAssignment();
                        public function loadContent(courseID:int):AsyncToken
                                  return this.remoteObject.loadContent(courseID);
              You can also add a Responder in the class itself to do this, but I prefer to call disconnect() externally (in the business logic layer), because there are instances where you do not want to automatically disconnect.
