1. Re: Adobe Reader 8.1.0
pwillener Aug 3, 2010 6:21 PM (in response to bigbob69)You deleted Adobe Reader, or you uninstalled it?
What Adobe Reader version shows in Add/Remove Programs?
3. Re: Adobe Reader 8.1.0
pwillener Aug 3, 2010 9:52 PM (in response to bigbob69)Can you open Adobe Reader by itself (without clicking on a PDF file)?
If yes, what version does it give you when you click on Help | About Adobe Reader ?
4. Re: Adobe Reader 8.1.0
bigbob69 Aug 4, 2010 5:26 AM (in response to pwillener)Yes I can open Adobe and it is version 9.3
5. Re: Adobe Reader 8.1.0
pwillener Aug 5, 2010 12:43 AM (in response to bigbob69)When you open Adobe Reader 9.3 by itself, it will not try to install 8.1.0?
But when you double-click on a PDF, then it will launch the 8.1.0 install, is that correct?
Open a Command Prompt (Start | Run | type
cmd
), then inside the Command Prompt typeassoc .pdf
- what is the reply from the command? (Typeexit
to close the Command Prompt.) -
6. Re: Adobe Reader 8.1.0
bigbob69 Aug 5, 2010 4:55 AM (in response to pwillener)When I click the start command - there is no "run" choice - I am running
Vista with the latest updates - and you are correct about what takes place -
9.3 will open OK but the problem arises when I try to open a pdf file.
