This content has been marked as final.
Show 7 replies
1. Re: CSS trouble
Newsgroup_User Aug 24, 2007 8:41 AM (in response to spdorsey6969)First thing you would need to do would be to fix these 117 errors -
http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fwww.dorseygraphics.com%2Freview%2 Ftopaz%2F
Many of them arise because you have specifies XHTML in the doctype, but you
have not use XHTML syntax for your tags....
Murray --- ICQ 71997575
Adobe Community Expert
(If you *MUST* email me, don't LAUGH when you do so!)
http://www.dreamweavermx-templates.com - Template Triage!
http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
http://www.dwfaq.com - DW FAQs, Tutorials & Resources
http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
"spdorsey" <webforumsuser@macromedia.com> wrote in message
news:famt3s$b0r$1@forums.macromedia.com...
> Hello
> I'm working on a page template that is giving me a hard time.
> It has a DIV box which contains other DIV boxes. This main DIV needs a
> dotted line going vertically down the middle, separating two virtual
> columns. I
> used a "repeat-y" background to accomplish this, and ot works great - but
> only
> in MSIE Win. In Firefox and Safari, it is not there at all.
> I placed a background color in the DIV, and it also only appears in MSIE
> Win. I'm not sure why this is.
> The page is at:
> http://www.dorseygraphics.com/review/topaz/
> and the CSS is at:
> http://www.dorseygraphics.com/review/topaz/css/main.css
> The CSS has not been optimized or cleaned up at all yet. The page is
> just
> now nearing the end of its first development phase.
> All I need is for the background to show up in all browsers. If you can
> help, PLEASE review the code and clue me in. I'm not sure what's wrong.
> Thanks,
> ----------------------S
2. Re: CSS trouble
spdorsey6969 Aug 24, 2007 9:10 AM (in response to spdorsey6969)Is it correct to assume that you are referring to the absence of XHTML syntax in my code?
I believe I have remedied that by adding self-closing tags and thusly bringing my W3C errors from 117 to 9. I'm working on getting rid of those pesky 9 right now.
I have not yet validated the CSS, as it is still being written. I plan to do that in the next day or 2.
After fixing 108 of the W3C errors, the background is still not drawing correctly in the "rightContent" DIV in Safari/Firefox.
Any ideas?
------------------------S
3. Re: CSS trouble
Newsgroup_User Aug 24, 2007 9:30 AM (in response to spdorsey6969)> Is it correct to assume that you are referring to the absence of XHTML
> syntax
> in my code?
Yes. DW will do that for you, you know? Use FILE | Convert....
All of your divs are position:relative - why is that?
I believe your image problem is this -
rightContent {
position:relative;
float: none;
width: 640px;
margin: 8px 0px 0px 16px;
padding: 0px 0px 0px 0px;
z-index: 9;
background-color: blue;
background:
url("file:///http|//www.dorseygraphics.com/review/topaz/images/separator_v.gif");
background-repeat: repeat-y;
background-position: center;
You have used the background (shorthand) style with just an image
specification. I believe that you MUST supply a color if you are going to
use the shorthand. Try changing that to background-image, or add the blue
to the style, e.g.,
background: blue url(...);
news:famvtu$e5p$1@forums.macromedia.com...
> syntax
> in my code?
> pesky
> 9 right now.
> to do
> Any ideas?
4. Re: CSS trouble
spdorsey6969 Aug 24, 2007 9:31 AM (in response to spdorsey6969)The HTML check out on W3C now.
I have also adjusted the CSS so that it only yields warnings, no errors.
The background problem is still occurring.
--------------S -
5. CSS trouble
spdorsey6969 Aug 24, 2007 9:36 AM (in response to spdorsey6969)Looks like we both posted at the same time there.
I just saw your post about using the shorthand. I removed the shorthand syntax (was not aware that a background color must be used with shorthand, that's a handy tip!) but problem still exists.
I commented the "background-repeat" tag in order to make the BG more visible in Safari/FF, and it is not showing up at all.
I'm also open to better ways of creating that vertical line, in case using a background image is not the best way.
----------S -
6. Re: CSS trouble
spdorsey6969 Aug 24, 2007 11:08 AM (in response to spdorsey6969)Just spoke with the Client.
It looks like this vertical separator would need to work also on uneven column widths, so the background centered image will not do the trick.
Not sure what to do.
7. Re: CSS trouble
Newsgroup_User Aug 24, 2007 11:15 AM (in response to spdorsey6969)Get rid of the relative positioning for starters....
news:fan6qi$lkl$1@forums.macromedia.com...
> Thanks,
