16 Replies Latest reply on Aug 4, 2010 1:41 PM by riograndeltarch
    Trouble Opening Elements Video in Quicktime
    riograndeltarch
      I am having trouble with saving my elements video to be viewed in Quicktime. I can save it fine, but when it iopens in
      Quicktime the video is out of sync a little with the audio.
      I am taking video classes and it is required to be able to open them in Quicktime. I almost tend to think it is a compression issue of some sort,
      but from what I understand they should be compatible.
      Any ideas...........anyone???
      Jennie
        • 1. Re: Trouble Opening Elements Video in Quicktime
          the_wine_snob Level 9
          Jennie,
          Welcome to the forum.
          Please tell us about your Project Preset, your source footage (the Video Clips) and also your MOV Export/Share settings used.
          Good luck with the classes, and we should be able to come up with a method to keep sync.
          • 2. Re: Trouble Opening Elements Video in Quicktime
            riograndeltarch Level 1
            Hunt,
            Thank you! My gosh,I never expected such a fast reply.
            I will send you that information first thing in the morning before I go to the Office.
            Thank you again,
            Jennie
            • 3. Re: Trouble Opening Elements Video in Quicktime
              Hunt,
              My footage comes from the school for three clips, stock footage, which is AIO, the Art Institute of Pittsburgh online where I am getting a
              Bachelors in Web Design. My other two clips are footage that was sent to me from a classmate. The whole video for this assignment id only
              90 seconds.
              On Elements, from Share to Personal Computer to save my settings are 320x240, fps is 29.97.Basic video settings are at Sorenson Spark,
              with an option for 0n2VP6.
              Settings when I scroll down to save in Quictime are H.264 foe Video Codec....fps is 15....Quality is 50.
              Preset for export is128KDual ISDN.
              Please let me know if i am miising anything here.I don't have a problem if you want to see this short clip sent to you.
              It is of waterfalls.
              Thank you much for your help and expertise on this.
              Jennie
              • 4. Re: Trouble Opening Elements Video in Quicktime
                Jennie, what are you saving the clips to MOVs for? What kind of device do you ultimately plan to play them on? That will help determine which settings you use to export it at.
                • 5. Re: Trouble Opening Elements Video in Quicktime
                  Though of course the other issue is that the video you're using as your source video is pretty non-standard. That may be why you're not getting any audio.
                  You may need to convert those files to something more standard before you bring them into Premiere Elements in order to have any success working with them.
                  • 6. Re: Trouble Opening Elements Video in Quicktime
                    This is for a simple school project. She wants them saved to  Quicktime so
                    everyone in class will be able to view it. Saving it to .mov in  Quicktime
                    to have open properly, is the end of the journey.
                    Thank you....Jennie
                    In a message dated 8/4/2010 7:38:49 AM Central Daylight Time,
                    forums@adobe.com writes:
                    • 7. Re: Trouble Opening Elements Video in Quicktime
                      What would you suggest more standard for files?
                      Also, these clips of  waterfalls....any way of slowing the motion down,
                      without affecting the time  frame.
                      I would like to slow down the motion of the waterfalls in the slides if
                      possible.
                      Thank you
                      Jennie
                      In a message dated 8/4/2010 7:39:57 AM Central Daylight Time,
                      audio.
                      them.
                      • 8. Re: Trouble Opening Elements Video in Quicktime
                        Jennie,
                        Going back to the source footage, do you know the details of those files?
                        If necessary, you can use the great, free utility, G-SPOT to gather all of the details. G-Spot will give you details about both the Video and the Audio in those files. As you really have two sources, I'd run each type (the stock) and the other student's files through G-Spot and post a screen-cap of the program's screen, so that we can see those details. There might well be something there, that will point to the issue.
                        Also, when you start a Project, you are prompted to define a New Project. What are the specs. of that Project? The settings in the Project should match the specs. of the source footage 100%, or one will have issues.
                        Now, back in that Project, in PrE, when you play the Timeline, I assume that you have the full Audio, which is in sync. Is that correct?
                        I notice that the FPS = 15. Going back to the source footage, does that match the FPS of that source footage? Above, I suggest how to find out those details. If this does not match the FPS of the source footage, is there a compelling reason to alter this?
                        I understand outputting (Export/Share) to a different Frame Size (so long as it is the same Aspect Ratio), and that should not be part of the issue.
                        Last, some users (PrE and PrPro) have had issues with Apple's H.264 CODEC. That is probably the most common one, as it is installed with Apple's QT Player. As a bit of background, the CODEC is the device for both encoding and decoding AV files. For more background, this ARTICLE might be useful. There are a couple more, very popular H.264 CODEC's, that seem to give fewer problems, Lead and MainConcept.
                        • 9. Re: Trouble Opening Elements Video in Quicktime
                          Hope you don't mind my sticking my nose in here, but can I suggest short-cutting this whole process?
                          If all Jennie wants is to be able to convert her video into MOVs, it might make more sense to suggest that she just pick up a copy of Quicktime Pro for $29 from Apple.com.
                          Quicktime Pro can easily work with any one of those files, and it will easily and quickly convert them into any MOV format you want.
                          Running those files through Premiere Elements just to convert them from one Quicktime format to another is a little like driving from Cleveland to Akron by way of New Orleans. Particularly when working with video, simple, direct solutions are by far the best! (This will also resolve her trying to figure out why Premiere Elements isn't able to assimilate the source video's audio track.)
                          • 10. Re: Trouble Opening Elements Video in Quicktime
                            I never mind a pair of expert eyes being involved in a problem!
                            You make a good point. If all that is needed is the basic assembly of three Clips, then QT Pro should do a fine job of that, with no need to go beyond that program.
                            The process of assembly with QT Pro is simple - just Open Clip A, run the CTI (Current Time Indicator) to the end of that Clip, drag Clip B into the screen, and then drag Clip C into the Screen. When done, one can Export the combined footage, or if it's all in MOV format and of the same specs., just do a Save.
                            Thanks, as always, for the comments. The goal is to get Jennie's output to play correctly.
                            • 11. Re: Trouble Opening Elements Video in Quicktime
                              Thank you for the input. I do have QuickTime Pro and my clips, which are
                              six at 15 sec a piece.
                              My audio is what seems to mess up a bit, especially at the end. Let me give
                              all this another shot and see what happens.
                              If I still have priblems..........I'll be back.
                              Thank you so much for the help!!
                              Jennie
                              • 12. Re: Trouble Opening Elements Video in Quicktime
                                If I still have problems..........I'll be back.
                                Jennie
                                In a message dated 8/4/2010 9:10:04 AM Central Daylight Time,
                                • 13. Re: Trouble Opening Elements Video in Quicktime
                                  If you have QT Pro, and only need to assemble the three Clips into a single H.264 file, then I would use that, and omit PrE from the mix, as Steve suggests. Things will be very simple then. Also, with the CTI (Current Time Indicator) on QT Pro, you can even do simple Trims, with your Clips. For this type of work, QT Pro is a handy tool.
                                  I use it for simple MP4, or MOV assembly, and for converting from those formats to something that I can use in my full-featured NLE (Non Linear Editor) programs.
                                  • 14. Re: Trouble Opening Elements Video in Quicktime
                                    Thank you; and I'll keep that in mind on furture use.
                                    This class involves, text, transtions and effects of which a dideo editing
                                    program is almost an essential.
                                    It does seem some oin class have better luck with Elements Premier  Pro. I
                                    don't want to get a new program with only two weeks left to this  class.
                                    Would you know why the Premier Pro would would better and if there is  an
                                    upgrade from the Elements 8??
                                    Jennie
                                    In a message dated 8/4/2010 9:39:27 AM Central Daylight Time,
                                    Editor) programs.
                                    Good  luck,
                                    • 15. Re: Trouble Opening Elements Video in Quicktime
                                      The problem is your source video. You've got some pretty outrageous formats going there!
                                      If you want to edit them with Premiere Elements, you likely can -- if you convert them to DV-AVIs first.
                                      Quicktime Pro should be able to convert each of those videos to DV-AVIs. Then, if you set Premiere Elements up for DV video, they should work perfectly.
                                      You can then use Share/Personal Computer/MOV to output your video as a 640x480 video.
                                      • 16. Re: Trouble Opening Elements Video in Quicktime
                                        Thank you very much. I will try that and see what happens!!
                                        Jennie
