0 Replies Latest reply on Aug 3, 2010 11:32 PM by Deh Bontempos
    whats the best practice to simply manage data using php sql?
    Deh Bontempos
      Hi
      I'm trying to follow some tutorials but there is too much old material and I'm getting confused.
      This is basic. I have a db and I want to movement data from flex.
      So, this is how I'm trying to do so. As a newbie, I will try to be clear.
      I have created a simple table called "teste" using myphpadmin with only 2 fields for testing.  (id, name).
      I have created the services automaticly using flex to generate a php code.
      This code is a simple exercise with buttons to add, update, and delete a Item.
      Although there is a lot of auto-generated code, I had a lot of work (due to my ignorance) to make it work.
      It fairly works, but I know veteran users would make it better, smarter, shorter, and ALL I WANT is a better (and simple) example to follow
      Please.
      Thanks in advance
      ps. I have set my table field "name" to the 'utf8_unicode_ci' while creating it and I it seems the adobe's generated php can't handle latin chars.
      THE CODE AS FOLLOWS:
                        xmlns:mx="library://ns.adobe.com/flex/mx"
                        minWidth="955" minHeight="600"
                        xmlns:valueObjects="valueObjects.*"
                        xmlns:testeservice="services.testeservice.*"
                        creationComplete="application1_creationCompleteHandler()" >
      <fx:Script>
                <![CDATA[
                     import mx.collections.ArrayCollection;
                     import mx.controls.Alert;
                     import mx.events.FlexEvent;
                     import mx.events.ListEvent;
                     import spark.events.IndexChangeEvent;
                     import spark.events.TextOperationEvent;
                     //selected item
                     public var selId:int;
                     //------GET ITEM (init)------------------------------------------------------
                     protected function application1_creationCompleteHandler():void
                          tx_edit.addEventListener(KeyboardEvent.KEY_UP,parallelEdit)
                          getAllTesteResult.token = testeService.getAllTeste();
                     //------SELECTED ITEM ID------------------------------------------------------
                     protected function list_changeHandler(event:IndexChangeEvent):void
                          selId = event.currentTarget.selectedItem.id;
                          lb_selectedId.text = "sel id: "+ selId;
                          if(tb_edit.selected) tx_edit.text = event.currentTarget.selectedItem.name;
                     //------ADD ITEM-----------------------------------------------------
                     protected function button_clickHandler(event:MouseEvent):void
                          var teste2:Teste     =     new Teste();
                          teste2.name                = nameTextInput.text;
                          createTesteResult.token = testeService.createTeste(teste2);
                          application1_creationCompleteHandler();
                     //------UPDATE ITEM (in parallel)-----------------------------------------------------
                     private function parallelEdit(e:KeyboardEvent):void
                          if(!isNaN(selId) && selId > 0){
                               if(tb_edit.selected){
                                    //uptadating
                                    teste2.id                     = selId;
                                    teste2.name                = tx_edit.text;
                                    updateTesteResult.token = testeService.updateTeste(teste2);
                     //------UPDATE ITEM (button click)-----------------------------------------------------
                     protected function button3_clickHandler(event:MouseEvent):void
                          teste2.id                     = parseInt(idTextInput2.text);
                          teste2.name                = nameTextInput2.text;
                     //------DELETE ITEM------------------------------------------------------
                     protected function button2_clickHandler(event:MouseEvent):void
                          if(!isNaN(selId) && selId > 0)     deleteTesteResult.token = testeService.deleteTeste(selId);
           </fx:Script>
           <fx:Declarations>
                <!-- this part was mostly auto generated -->
                <valueObjects:Teste id="teste"/>
                <testeservice:TesteService id="testeService" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
                <s:CallResponder id="createTesteResult"/>
                <s:CallResponder id="getAllTesteResult"/>
                <s:CallResponder id="deleteTesteResult"/>
                <s:CallResponder id="updateTesteResult"/>
                <valueObjects:Teste id="teste2"/>
           </fx:Declarations>
                <!-- this are just visual objects. Renamed only necessary for this example
                      most lines were auto-generated-->
           <!--Create form -->
           <mx:Form defaultButton="{button}">
                <mx:FormItem label="Name">
                     <s:TextInput id="nameTextInput" text="{teste.name}"/>
                </mx:FormItem>
                <s:Button label="CreateTeste" id="button" click="button_clickHandler(event)"/>
           </mx:Form>
           <!--Create Result -->
           <mx:Form x="10" y="117">
                <mx:FormItem label="CreateTeste">
                     <s:TextInput id="createTesteTextInput" text="{createTesteResult.lastResult as int}" />
                </mx:FormItem>
           </mx:Form>
           <!--List -->
           <s:List x="10" y="179" id="list" labelField="name" change="list_changeHandler(event)">
                <s:AsyncListView  id="anta" list="{getAllTesteResult.lastResult}" />
           </s:List>
           <!--Update in parallel -->
           <s:Label x="147" y="179" id="lb_selectedId"/>
           <s:Button x="147" y="222" label="Remove" id="button2" click="button2_clickHandler(event)"/>
           <s:TextInput x="225" y="257" id="tx_edit"/>
           <s:ToggleButton x="147" y="257" label="Edit" id="tb_edit"  />
           <!--Update with button click -->
           <mx:Form defaultButton="{button3}" x="220" y="0">
                <mx:FormItem label="Id">
                     <s:TextInput id="idTextInput2" text="{teste2.id}"/>
                </mx:FormItem>
                     <s:TextInput id="nameTextInput2" text="{teste2.name}"/>
                </mx:FormItem>
                <s:Button label="UpdateTeste" id="button3" click="button3_clickHandler(event)"/>
           </mx:Form>
      </s:Application>
