3 Replies Latest reply on Aug 12, 2010 9:02 AM by rtalton
    Number Formatting
    samschauhan Level 1
      I want to format a number such that the preceding 0s are trimmed:
      00079 should be 79.
      Also I dont want the thousands separator to appear in bigger numbers:
      0007989999999 should be 7989999999 and not 7,98,99,99,999.
      Let me know the solution folks.
      SAM
        • 1. Re: Number Formatting
          BhaskerChari Level 4
          Hi Sam,
          You can make use of the function below to trim leading zeroes from a Number which is a String...
          private function trimZeroes():void
                     var strNum:String = "0007989999999";
                     for(var i:int=0;i<strNum.length;i++)
                      if(strNum.charAt(0) == "0")
                       strNum = strNum.substring(1,strNum.length);
                      else
               break;
          You can then Cast it to Number after Trim..
          Bhasker Chari
          • 2. Re: Number Formatting
            samschauhan Level 1
            Thanks.
            • 3. Re: Number Formatting
              rtalton Level 4
              Just use the Number class itself:
              Number('00079')// outputs 79
