2 Replies Latest reply on Aug 5, 2010 7:16 PM by Bill Gehrke
    Benchmark (PPBM5) and CS5 settings
    neebster2020 Level 1
      I recently did the new benchmark for CS5 (http://ppbm5.com/index.html) and followed the instructions in the Word document, including the part which says:
      "Check the scratch disk location. It should be the same as project."
      I would normally have set up my scratch disk to be different from my project disk, but presumed that this setting was part of the benchmark so that everyone would be the same.
      However looking at the results table on the web site I see that lots of people have specified different output/preview disks.  If this is OK, then could I suggest that the Read Me file be changed to let users know that they should specify their normal scratch disk set-up when doing the benchmark.
      I did do a search for this topic on this forum and couldn't find anything, however apologies if this has already been mentioned.
      I will re-do the benchmark, but with my scratch disk different to my project disk.
        • 1. Re: Benchmark (PPBM5) and CS5 settings
          Harm Millaard Level 7
          There is always the dilemma between allowing users to setup their disks as they want, one for project, one for media, one for exports and one for previews, or making it simple by using only one disk for everything.
          The dilemma is the script questions to ask about all the other locations and their characteristics. For most people the current 22 questions is already a burden, or at least a bore. Increasing the number of questions, that only applies to less than 50% of the participants if we look at the PPBM4 results, did not seem a good option and in our effort to KISS, we decided to leave out that option.
          If you have an investigative mind, you can manually modify the script to reflect your setup, but I would advise against it. During all the testing we have done, and Bill and I have each done multiple times the tests that are currently submitted, we have not found any sizable difference in results. This is due to the fact that the test methods have changed drastically in comparison to previous versions.
          Rendering is only done once per test, so the location of the previews is rather irrelevant and the previews generated are not used in all the other tests. For the remaining tests, Disk, MPEG and H.264, it is easy to export to another disk and modify the script accordingly, but apart from very esoteric disk setups like Studio North (9 x R3 and 5 x R3), the benefit will be marginal, especially on the two CPU intensive tests.
          If you look at the Disk test, which reads a lot of small files and writes one large file at the end, the read disk has long finished when the CPU has finally collected all material for writing, which is done in a single burst. It does not matter if that is written to a single disk A or a single disk B, because their burst rates are pretty much the same and any differences will be below the measurement accuracy anyway.
          Hope this explains it a bit why we chose for the KISS approach.
          • 2. Re: Benchmark (PPBM5) and CS5 settings
            Bill Gehrke Adobe Community Professional & MVP
            If you want to test out different locations for files then go back to PPBM4 and you have the options, it works perfectly well on CS5
